Question about NEC Computers & Internet
Monitor flickers, color turns pink - NEC Computers & Internet
This has happened to me before, seems when AVG is running is when it is noticable. After playing with the settings and doing a lot of googling and reading, my fix this time was to update the driver for the NEC monitor. It's working great for now.
Posted on Jul 28, 2008
2 Suggested Answers
octeks
  • 52 Answers
SOURCE: My LCD monitor turned Pink
The reason its pink is that the backlight bulb is on its last legs. They turn pink or reddish before they go out completely. Eventually the backlight will need to be replaced.
Please rate this fixya
thanks
Posted on May 04, 2009
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
Monitor color
replace signal cable your problem will be solved if persist then open the monitor and find out the dry solder and clear it
Apr 12, 2010 | Dell E173FP 17" LCD Monitor
Reddish picture when power on, screen flickers and then shuts off after 1 or 2 minutes
The red or pink color indicates one of the backlight tubes is failing. Only solution is to replace the bulb or replace the unit.
Monitor Mike
Jan 17, 2010 | HP L1706 17" LCD Monitor
My HP w1907 monitor less than a year old is turning pink!
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
Oct 05, 2009 | HP w1907 LCD Monitor
Color are messed up white is pink
Is it messed up if you plug in an external monitor? if no then something is messed up in the internal connection in the computer and you would need to take it apart and replug in the video cable on the back of the monitor panel.
Jun 14, 2009 | HP Pavilion dv6000z PC Notebook
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
NEC ACCUSYNC 900
Havent you got a person or a friend that has a puter to test the monitor??? This would be the best way as it could be the crt on the monitor or the crt driver board but before we go there we should make sure where the problem lies. Good Luck
May 12, 2006 | NEC AccuSync 900 19" CRT Monitor
Computers & Internet Logo
225 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
