DVD-300L-XAA SAYS CAN'T READ DISC- CHECK DISC NOTHING WRONG WITH DISC'S
  • bobksells Jul 30, 2008
    Thanks will try the laser. I cleaned the disc with no effect
    President:
  • 173 Answers
The majority of problems dealing with a dvd player not being able to read discs are because the discs are either dirty or have small scratches on them and the other common reason is because the optical laser lens inside the dvd player is dirty and needs cleaning.
Try cleaning the discs with regular running water in your kitchen sink. Wet the dvd and then apply a small amount of regular dish soap on your finger and rub it all over the the bottom side of the dvd until you have a slight lather. Then rinse the dvd really well and dry with a small cloth making sure you remove all water and smudges.
Clean the optical lens inside your dvd player.
Open the dvd tray by pushing the eject button and then turn off and unplug the dvd player from the outlet. Remove the top of the case by removing the screws on both sides of the player and there might be one or two in the back using a phillip head screw driver. Look inside the carriage and you will see a small glass looking bubble in the middle, that will be the optical lens. Take a few cu-tips and dip them in regular rubbing alcohol and shake off any excess and gently clean the optical lens with the cu-tip in a circular motion. Repeat the process a few times and then let air dry for 5 minutes. Replace the case and plug the dvd player back in and insert one of the discs you have cleaned using the dish soap and see if that has corrected the problem.
If this does not solve the problem it could be that the dvd tray is out of alignment or if the disc does not appear to be spinning up (which you can here) then the problem will spindle motor. These two things require someone with the proper tools and experience to install. Hope this helps and please let me know if you need further assistance.
If you would please rate my help, I would appreciate it very much. Thank you
Posted on Jul 27, 2008
Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
Keep getting incompatible disc error
what if you try other dvd-r brands. just a suggestion.
Sep 23, 2007 | JVC Everio Share Station DVD Burner Burner
When I put my disc in it loads...then it displays
Wrong disc usually indicates a problem with the lens mechanism of the DVD player. It can be dust/lint blocking the path of the laser there by preventing it from reading the disc or it can be a mechanical problem like lens out of alignment. You can attempt to clean the lens using a lens cleaner CD/DVD with liquid and see if it resolves the issue(you can get one for as low as 5$). Perform a dry cleaning first(without the liquid) and then with liquid(two drops on the brushes of the lens cleaner DVD that pop-up after the dry cleaning run. If it doesn't resolve the issue then you may have to get the lens mechanism checked by a qualified technician. You can search the fixya repair directory to find one in your area.
http://www.fixya.com/repair
Oct 12, 2009 | TruTech TT320
Roxi create de 9 write data to dvd+ successfully but nothing on d
I would make sure that the disc is finalized. Most drives will not read data on a disc without it being finalized.
Sep 16, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
Navigatgion DVD ROM Issue - Cannot Read Disc
there is an internal fault in the nav unit
Aug 21, 2009 | 2005 Jeep Grand Cherokee
Our dvd player is saying wrong disc all of a sudden.
IT could be 2 things : check the region of dvd , or clean the OPTICAL LENS directly with a dry Q tip gently , if it still reads " wrong disc" then replace the optical lens , AJ
Jul 09, 2009 | Coby DVD-514 DVD Player
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
May 03, 2009 | Spectroniq PD-1100 DVD Player
DVDs Wont play
Check the specs on your dvd player. Not all players will read dvd-r discs. Some players will only read commercially produced dvds. Hope this helps & please take a moment to rate my answer. Thanks.
Feb 08, 2009 | Coby DVD-224 DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
