I HAVE A PR200.2 MEMPHIS AMP THAT THE POWER LIGHT JUST FLASHES AND THE PROTECT LIGHT IS SOLID. WHY?
  • 905 Answers
SOURCE: Amp won't turn on
disconnect audio inputs and outputs and see if one of those are causing it , if it still does it with all audio inputs and outputs disconnected then there is a problem with the power amp
Posted on Oct 08, 2008
  • 77 Answers
SOURCE: kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Posted on Mar 09, 2009
  • 22 Answers
SOURCE: Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Posted on Mar 23, 2009
  • 15 Answers
SOURCE: When I hook power to my amp the protect light comes on.
when connecting or disconnecting 12v power dont let the screwdriver touch the screw in terminal and side of amp at same time it causes a short in amp send it in to the factory or it could be the internal battery is burnt out from crankin it to loud
Posted on May 22, 2009
yungdub
  • 93 Answers
SOURCE: protect light keeps coming on when i give my jensen amp power
Eith some wires touched, you dont have big enough fues or you have somehting hooked up wrong
Posted on Jun 14, 2009
Amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Dec 31, 2013 | Car Audio & Video
My Memphis Audio amps protect light will not shut off
Disconnect the speakers, power the system up, if the protection light goes off, there is problem with the speaker or speakers, if not check output transistors for leak or short.
Sep 10, 2013 | Audio Players & Recorders
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
Red light flashes on amp when you turn the ignition key.
It really sounds like a grounding problem. Recheck it make sure where it's attatched to the chassis is scraped to bare metal, an you used a clean, shiny bolt to attach it. Also us a voltmeter to check your power wire just to be sure it's not that, you should get 12-15 volts. Also just make sure none of your fuses are blown. And Use the voltmeter to check your REM wire, your should also be getting 12-15 volts there. If this doesn't fix your issue i'm at a loss to explain it..... Buy a new amp, and don't buy Boss, i've had lots, and lots of problems with them in the past.
Sep 12, 2009 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
Apr 13, 2009 | Car Audio & Video
Mar 22, 2009 | Car Audio & Video
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Amp hook up
If you are referring to a warning light on a car, unless you knicked a wire that caused a warning light to come on. It shouldn't matter if you have an aftermarket amp. If you are referring to a warning light on the amp. Make sure that you are not under driving the impedence and not shorting any wires. If you dont have any shorts, then your amplifier is probably done for. Because you might have a short internally. Unless it is just in protect mode. I had a memphis amp that went into protect mode, I set it off to the side for a for a week or so and was bored so i hooked it back up and it worked. It still works and that was about 2 years ago. Good luck.
-Andrew Hawkins
Sep 02, 2008 | Car Audio & Video
319 people viewed this question
 Grubhead
Grubhead
