Question about Friedrich Heating & Cooling
Friedrich EM18J34B - Unit will only operate in fan only mode. When turned to Cool or Heat modes nothing happens. Position of thermostat has no influence - the unit will not operate. Ideas?
Joe_Rex
  • 114 Answers
SOURCE: Short Cycling
COMPRESSORS HAVE AN INTERNAL T-STAT TO PROTECT THE WINDINGS ... SOME THING IS CAUSING YOUR COMPRESSOR TO RUN "HOT" THIS WILL KICK "IN & OUT" THE COMPRESSOR DURING COLLING OPERATION AND HEAT MODE (IF IT IS A HEAT-PUMP). 1ST THING TO EASILY CHECK IS THE CONDENSOR "OUT-SIDE" COIL. (CLEN BOTH WHILE YOU ARE AT IT). THESE FANS PULL THE AIR IN AND A BLOW OUT THE COIL .... ALL THE DIRT WILL BE ON THE INSIDE. 2ND THING IS THE FAN ITSEL OVER HEATING AN TURNING "OFF" ON ITS OWN "BUILT-IN POTECTION T-STAT". THIS WILL GIVE YOU THE IRRATIC OPERATION YOU ARE DESCRIBEING. I TEND TO THINK IT IS YOUR FAN MOTOR ... EASY TEST. TURN "OFF" EVERYTHING BUT THE FAN. SET IT FOR MANUAL "RUN ALL THE TIME" POSITION. THE FAN SHOULD NOT KICK OFF !!! IF IT DOES YOU FOUND THE PROBLEM. IF IT DOES TURN OFF IT CAN BE A WEAK CAPACITOR. UNITS VARY ON WETHER THE CAPACITOR IS FOR COMPRESSOR/FAN OR HAS A SEPERATE CAPACITOR FOR EACH. CAPACITORS ARE NOT EXPENSIVE. HOPE THAT CAN NARROW YOUR PROBLEM DOWN
Posted on May 07, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 57 Answers
SOURCE: fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
Posted on May 20, 2008
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
SOURCE: Carrier Weathermaker 8000Vs
This is nothing short of a circuit board fan relay of a bad motor.. to find out if the motor is good, unplugg the black & white wire , in which white =ground black=hi-speed 120volts and conect them to power -ground and see if the motor works..if does, then its the fan circuit board if not then its a bad motor...
Posted on Aug 25, 2008
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
How do turn my ac on?
you should move the switch to the "cool" mode and turn the thermostat to a lower setting, leave the fan in the auto position,verify that the breakers are on to your ac unit and that the wiring is correct for the operation of the ac
Jul 10, 2009 | Heating & Cooling
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Honeywell thermostat
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
