My 1988 yamaha yz80 clutch pin isnt hitting the clutch plate as much as i think it should be. what do i do?
SOURCE: yamaha yz80 wont kickstart
There is a "C" clip with a stem at a right angle as a part of the clip. This is a part of the kick starter mechanics. Replace the clip. It is about one inch in diameter.
SOURCE: 89 yamaha yz80 changed clutch will not start now
i have a picture of the kick starter i can send you it sounds like you have it installed wrong
SOURCE: yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications
Engine
Engine Type
2-stroke
Displacement
83 cc
Bore x Stroke
47 mm x 47 mm
Compression Ratio
8.2:1
Engine Cooling
Liquid
Carburetion
Carburetor
26mm Mikuni
Transmission
Transmission
6 - speed
Chassis
Wheelbase
49.5 in
Ground Clearance
13.7 in
Seat Height
33.6 in
Fuel Tank Capacity
1.3 gallons
Forks
Forks
33mm Kayaba
Fork Travel
10.8 in
Shock
Shock(s)
Kayaba
Shock Travel
11.1 in
Wheels and Tires
Front Wheel
17 in
Rear Wheel
14 in
Brakes
disk/disk
Other Information
Intended Use
Motocross
Color Scheme
Blue
Cost when new
$3199
SOURCE: my 1988 yamaha fz750 is
Where it is leaking is most likely the problem.
try bleeding it and see if you get any pressure at the slave.
