Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer is leaking from underneath......
Our washing machine is leaking from underneath the machine?
  • hoglandl Dec 28, 2008
    I to am having trouble with water coming from under the machine. This is the 2nd whirlpool that I have had trouble with. Think it is time to change brands. T. Hogland
  • Whirlpool Master
  • 5,568 Answers
In my experience, the pump will be at fault. The shaft seals die and when that occurs, it leaks.
About any handy person can remove and replace these although expect some skinned knuckles.
Rarely, the housing of the pump (cheap plastic) will crack or the mixing solenoid will crack and leak.
The mixing solenoid is located (and part of) the fittings to which you connect your water supply.
Check to see if you have a Johnstone Supply in your area. Although they are a wholesale source for repair folks, I have never been turned away and the prices are 1/3 - 1/2 of what one will pay at an \'authorized dealer.\'
Posted on Aug 03, 2008
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
SOURCE: leak coming from bottom of washing machine
It might not have totally emptied during the last cycle.  Try laying the hose where the water empties down.  The level of the hose needs to be lower than the water level to be able to drain.  Make sure you have a bucket to empty in to.
Posted on Oct 11, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
futureloginn
  • 734 Answers
SOURCE: leaking washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
  • 41 Answers
SOURCE: washing machine leaks from underneath after rinse cycle
i would 1st look to make sure the drain hose is not loose or broken. be sure it is staying in the drain pipe in the wall.it could be a cracked housing on your pump. hope this helps
Posted on Jul 11, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Water underneath unit?
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
My washer is leaking water from underneath after it washes
Hi Please get me a model # so I can assist you.
Vic
May 27, 2009 | Washing Machines
Washer leaks from underneath
It's still under warranty. Call frigidaire and find out who the closest servicer is. Or check this out: http://www.frigidaire.com/support/service_locator.asp
Oct 06, 2008 | Frigidaire Affinity ATF7000E Front Load...
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Washer leaking water from underneath
May 11, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
