I have a OLD Zenith TV and lost the remote and want to tune to channel 60 through its on screen menu, so I can receive my satellite signal. I've tried the auto channel select and it doesn't show any. I tried to go manual and it don't work either. What trick did the satellite install know that someone out there can help me with. It did work Bob
Can't afford to pay for services, Thanks
Posted on Jul 28, 2008
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
The colours on my tv screen are all green and distorted can you tell me what the problem is its a samsung and its only 2 years old
YOU MAY HAVE CONNECTED THE RECEIVER TO AN INPUT ON THE TV THAT IS INCORRECT FOR THE SIGNAL OUTPUT FROM THE RECEIVER.
GET YOUR TV BACK ON THE CORRECT INPUT OR CHANNEL...CYCLE YOUR TV THROUGH ITS INPUTS BY...PRESSING THE INPUT, SOURCE, OR TV/VIDEO BUTTON ON YOUR TV REMOTE OR THE TV ITSELF.
IF THE PICTURE IS NOT RESTORED, CHANGE YOU TV TO CHANNEL 3 OR 4 USING TV REMOTE OR THE TV ITSELF.
IF THIS IS A 2ND TV, TUNE YOUR TV TO CHANNEL 60-73 USING THE BUTTONS ON YOUR TV REMOTE OR THE TV ITSELF.
ONCE YOUR TV PICTURE IS RESTORED, PRESS AND RELEASE THE SAT MODE BUTTON ON YOUR REMOTE TO ENSURE YOU'RE IN THE PROPER MODE FOR CONTROLLING YOUR RECEIVER.
YOU CAN ACCESS YOUR FEATURES, SETTINGS ETC, ON YOUR MENU BUTTON ON YOUR TV REMOTE.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Samsung Televison & Video
I need to reprogram my zenith sy2568s tv to recieve available channels
With the remote control:
1. Press Menu repeatedly to view the Setup Menu. 2. Select Auto Program. 3. Use the Left/Right Arrows to advance to the next menu. 4. Select either OFF AIR ANTENNA or CABLE TV.* 5. Use the Left/Right Arrows to advance to begin the channel search.
*NOTE: THIS TELEVISION WAS MANUFACTURED IN 1996 AND HAS AN ANALOG TUNER ONLY AND WILL NOT RECEIVE OVER THE AIR SIGNALS AS ALL OVER THE AIR SIGNALS ARE DIGITAL NOW AS OF 2009. IN ORDER TO USE THIS TELEVISION SET FOR OVER THE AIR SIGNALS YOU WILL NEED A DIGITAL TO ANALOG CONVERTER BOX AVAILABLE FOR BETWEEN $30 AND $60. CHECK EBAY FOR GOOD DEALS ON THEM.
Apr 23, 2011 | Zenith SY2568S TV
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
djpeter770
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Model LD 200 EMB
This may sound stupid and not help anything but I would change the batteries in the remote first; that's the simplest possibility.
What the set is doing is selecting a function, the first is 'Auto tune' during which the set is looking for usable channels on the 'off air' (antenna) input. I suspect you have cable or satellite meaning that there will not be any signal at the antenna input and the set just looks at each standard channel frequency and then gives up.
The language thing; this is curious but also a sign that it has switched to the menu mode where you also need to be if you want to do a channel search on purpose.
If the remote is not at fault, then it is an internal problem you will not be able to repair on your own.
The circuitry that interprets the received infrared signal from your remote has started producing noise or the output from that after a decoder, has gone noisy and is just choosing functions on its own.
The blue screen is what most sets use as a default when no signal is found at any input.
Unfortunately. Emerson, RCA, Zenith and a few others are US names we once trusted but now have been acquired by Asian manufacturers who are building junk with labor pulled from the fields to assemble high tech gear.
Aug 27, 2008 | Emerson EWL20D6 Television
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Zenith wont tune channels
You must get a proper replacement remote control, once you can access the menu and find you cannot store above 13, place another post and i will help you further.
Oct 11, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
