If I manually turn on the set the power light blinks red 5 times then pauses and repeats this without turning on. If I use the remote it will turn on for about a minute or two, then the screen goes all black with no sound for about 30 seconds. It will play for a minute or two and then repeats the same cycle. Is this problem different from the 6 blinking lights?
Thanks,
It works!! First i took off the front panel. Just check your manual
for instructions, very easy to do. If you do not have a manual just
down load one from google.. The instruction are easy to follow. The
screw they have you loosen with a alan wrench is attached to the
plastic, so you do not have to worry about dropping it inside the tv.
Removing the lamp was simple. once out you will notice on either side
are two small mesh screens. One of mine was 80% blocked with dust, the
other side was only 30-40% covered. I used a vacuum to remove the
blockage, i did not want the dust and dirt to go inside the bulb. i
then cleaned all around the lamp. Reinstalled, and we are go to go.
The kids are happy and i am happier since my wife not be buying a new
TV. if this does not work it is time to replace the bulb.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did
turn off my TV, then turned on. I nothiced a red blinking light. Mine
flashed 5 times. After some reserch, 5 times is video related, bulb or
video board. google red flashing light with the model you have and you
will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
same problem
