Question about Bosch Axxis WFL 2060 Front Load Washer
Won't fill with water
We just moved my mothers Bosch Axxis WFL 2060 Front loader to our home. It will not fill with water. We tried all the basic things - water is on, water pressure is fine, there are no kinks in the hose. Once pressing start it makes sound, lockes the doors etc. The water does not run into the soap dispencer, nor anywhere else into the mashine. Help what is the problem.
    Scholar:
  • 97 Answers
Hiya
sounds like a faulty inlet valve, but as the machine has just been moved i would check the water taps, if they are the red and blue plastic ones these tend to go brittle and snap inside, so when you turn them you automatically presume the water is on, but in reality the plastic tap turns but the valve underneath has'nt.
easiest way to check is turn the taps into the off position then remove from the machine and hold into a bucket or large dish, turn on one at a time, if they turn on then its the inlet valve on the machine at fault.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 06, 2008
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My bosch WFL 2060 Front Loader Washing machine stops mid-way ..
hiya
i'll need a little more info if you can, like what exactly does the machine do or not do?
does it make any strange noises?
does it trip out the electics?
the more you can answer for me the better the diagnoses
thanks kj
Nov 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
116 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
