Question about LG Washing Machines
I want to stack my LG TROMM washer and dryer. How do I accomplish this task?
Called Home Depot and they explained process. thanks
Posted on Jul 28, 2008
Lg tromm gas dryer burning smell shuts off
Hello Debi;
My name is Peter. I am a retired field service appliance technician.
You have a dangerous situation.
1.) First, your dryer is shutting down because your dryer is plugged up with lint and there is no air flow. You need to remove the top cover and control panel, the front cover and if your hot air distribution manifold id in the back or front end, remove that and clean. With a dry rag (DO NOT USE LIQUID CLEANERS), wipe the grease and grime off all components.
2.) The burning smell is the lint burning. Fortunately, due to the lack of air, the lint is being extinguished.
So far you are lucky. You have not had a major fire. DO NOT USE THE DRYER UNTIL THE ABOVE TASK HAS BEEN ACCOMPLISHED.
I wish I could provide you with more specific information on your dryer, but you did not provide a model number.
Nov 20, 2014 | LG Dryers
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
My lg tromm front load washer stops at 37 minutes
check the drainage pump or electronic board is faulty
Oct 20, 2014 | LG Tromm Front Load Washer And Dryer Set
Manual for lg tromm dryer
Hi bbdesertrose..
Go to the following webpage and download your user manual
Please take time to rate me
http://search-manual-online.com/lg-tromm-washer-manual.html
Sep 17, 2011 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
How to stack instructions
I just bought one of these, and the install is pretty simple.
you have 3 pieces, 2 of them go on the sides, 1 goes across the front.
you lay the side pieces on top of the washer so that the little tabe are sticking up,  the end that has 2 tabs and a hole for the screw goes at the back.  once they are laid in place, you put 1 screwn in each piece on the back of the washer (there are holes in the washer for this already) then you put the dryer on to so that the little tabs that stick up kind of hold the feet.
you put the front bar on last so that it's tabs hold onto the front feet, then you screw both ends of the front bar into the side bars.
Mar 18, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm door reversal
IF YOU SWITCH THE DOOR YOU MIGHT WANT TO MAKE SURE THERES NO SWITCH OR ANYTHING THAT THE DRYER READS TO SAY THAT THE DOOR IS SHUT OR OPEN IF NOTHING THEN IT SHOULD BE A PRETTY EASY SWITCH
Mar 09, 2009 | LG DLE2514 Electric Dryer
Took the lint screen out and forgot to put it back in and a kneehigh went in the vent and made a noise. Is there any way to get it out without repairman. I cannot see the nylon and the machine is stacked...
This being stacked makes things a lot more of a pain. Disconnect power.
  • Remove three phillips head screw at the back side of the dryer top
  • Slide top back about an inch or so and lift off
  • Remove two phillips head screws at 5 and 7 O'clock position on dryer bulkhead just behind dryer door.
  • Remove two phillips head screws on top front edge of dryer
  • Tilt dryer front forward at top and unplug door switch at top of door and light socket at top left.
  • Lift off dryer front, holding until you can unplug the moisture sensor wire at the bottom, then set aside.
  • Remove the four phillips head screws at the sides of the dryer holding the front drum support assembly.
  • Lift up assembly and pull toward you to remove.
  • You now have access to the blower.
  • Front of blower can be removed. (1/4 hex screws)
Oct 03, 2008 | LG Dryers
Washing Machines Logo
78 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
