Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension E510
My desktop computer (Dell Dimension E510) will not stay on during star-up. It constantly turns on and off. What can this problem be and what caused it.
    Genius:
  • Dell Master
  • 1,056 Answers
I have had that happen on Optiplex units. It is a sign that the motherboard is going or has gone bad. Cure is to replace the motherboard.
Posted on Jul 27, 2008
  • 99 Answers
A few potential problems:
1. Your CPU fan isn't working, causing your CPU to overheat and then turn off the system
2. Your power supply is faulty
3. A capacitor has blown on your motherboard
Give us more details on your problem so we can figure out what's going on
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
I have a dell dimension E510 computer it turns on but it has no vedeo or power to the key board
What exactly can you see on the screen?
A blinking cursor?
Entering power saving mode?
Try to unplug the cables and plug it back in,it should work.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 08, 2011 | Dell Dimension™ E510 PC Desktop
Computer fan running constantly
Computer fan will always run and act as a ventilator to send the heat outside the CPU.
So, don't worry, be cool.
Thank you.
Jun 10, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
The dell dimension E510 powers off and will not stay on
This info is not enough to give you a specific solution. Try this: Press and hold on/off button for 3 seconds. Turn on button, press f8 continuosly to os start menu, choose safe mode, check sleep and hibernation settings, test for malware/spyware, check startups - run msconfig, disable all startups if needed.
Dec 16, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension E510 DVD Burner
Try to use cd cleaner to clean the lens, if this doesnot work, this means your lens is died, change the DVD Rom.
Thanks for using Fixya
Oct 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Jan 24, 2009 | Dell Dimension E510 PC Desktop
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
169 people viewed this question
Alun Cox
