Way to small. The shelves in the top portion will not hold anything but very small items, the shelves in the door only hold a few bottoms of water.
I have the new black 23.5 GE Profile and I think they misshipped this unit, because it belongs in a very small apartment. Very poor, no, terrible design for the money.
Inspect door seals for shifting, bunching, and tears and adjust or replace them. Inspect shelving in compartment to make sure of proper positioning. Inspect door baskets for item protruding over the top and holding door back. Inspect door for loose hinges allowing doors to sag.
There is no lock on your refrigerator for either door. The lock/unlock button is only for the dispenser to keep small children from dispensing ice or water. If your door won't open it could be a few things. First, a package on one of the shelves dropped and is jamming the door on the inside. May require removal of the top hinge so you can tilt the door top forward and look inside to see what happened. Next, you may have one of the door hinges that actually broke and is keeping the door from opening. You will need to look close at both hinges but I would guess the bottom hinge would cause this more that the top since the door weight is all on the bottom hinge. The only thing that holds the doors closed is a magnetic gasket on most side by side models under normal conditions.
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
I think my problem seems better now that I"ve lowered the temp to almost off. Oh by the way, what made you think I have a side by side. What I do have ias a 10 year old single door kenmore.
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
