Question about PfaFF Creative 7570
My Pfaff 1222 SE circe 1981,sewing machine went completely dead. All plugs ok. Belt a tiny bit loose. Never had a problem in 28 years. It just went silent.
  • 632 Answers
Your foot controler might be bad.
Posted on Jul 27, 2009
  • 1 more comment
  • Ed Paje Apr 26, 2010
    Either you push button switch is broken or your foot controller is fried inside. You can purchase both parts from ebay under PFAFF parts. Good luck
  • Ed Paje May 07, 2010
    Could be a bad power switch. This can easily be purchased in ebay, just use it's search engine, there must be 10 at a given time.
  • scuba812 Mar 11, 2011
    How do you reach the push button switch on a pfaff 1222?. Is it from under the basae plate or do you remove the housing on top???
SewExpress
  • 41 Answers
SOURCE: pfaff 1222 belt
Hi - a few suggestions:
  1. May just need a good thorough service - generally a good idea to have it completely gone over - by an experienced Pfaff tech - every year or 2. Internal parts can dry out and simply get jammed.
  2. The timing could be off - again an experienced tech can take care of.
  3. The cam-stack (the part that actually makes your stitch formations) may have cracked. At the age of your machine, this isn't uncommon.
At the age of your machine, many other owners actually have it "rebuilt" by an authorized Pfaff service person. This model is one of those that's worth the investment compared to buying a new machine of the same caliber/quality.
If you are comfortable removing the top cover, you may be able to look at the internal parts to see if anything is broken. This will at least give you an idea of what may be happening.
Many authorized techs will not charge you to look at the machine and give you a quote. We'd suggest calling a few sewing machine stores in your area. Don't hesitate to ask friends for their recommendation of a good service person.
Hope this helps - please don't hesitate to respond if you need further info or clarification.
Happy sewing,
Kim & Linnette
Posted on Jun 13, 2008
SOURCE: changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: when I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Posted on Jun 14, 2009
  • 632 Answers
SOURCE: my pfaff 1222 SE has a broken switch. I don't
I foud the correct power switch for your model (I have the same machine). This is located under the dark brown plastic cover. You can buy it on ebay and the item # 360066934338.
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
I need a foot controller power cord for a Pfaff 1222 SE
Check with your local Pfaff dealer, search online for sewing machine suppliers, or look on eBay.
Oct 23, 2015 | PfaFF Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
I need a service manual for Pfaff model 1222e
You can download it from PFAFF service manuals in PDF formats. It may not mention an E or an SE after the model #1222 because the difference is just the motor rating and different feet it came with, the rest are all the same.
Feb 01, 2010 | PfaFF Sewing Machines
My pfaff 1222 SE has a broken switch. I don't
Jul 15, 2009 | PfaFF Creative 7570
fuse needs replacement
Aug 22, 2008 | Sewing Machines
Pfaff 1222 belt
Happy sewing,
Kim & Linnette
Feb 25, 2008 | PfaFF Tiptronic 2030
Changing Pfaff 1222 sewing machine belt
Sewing Machines Logo
535 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
