Question about Kenmore 22422 Top Load Washer
Kenmore 110.20904990 top load washer
Washer will drain but wil not spin if i help it ,it will spinthen it locks up the tub moves more side to side than before . i looked under and didnt see anything that was broke. there are two little plastic cups with pins in it .the pins take a cotter pin ,but didnt find one,they are mounted to the frame just below the suspension plate
    Scholar:
  • 150 Answers
Ignore those cups with the pins those pins were the travel lock devices and the cotters were attached to the yellow lanyard that whoever first put the unit into service pulled off of the back of the unit per instuctions. this pulled the cotters out of the pins which then fell into those cups. the cotters came out with the lanyard and are long gone. the not spinning is due to something in the clutch not working properly. the moving to one side is caused by one of the pads that the suspension plate rides on being missing. you can look at the diagram on sears website at the parts look up and see were the pads go and find out what the suspension plate is and such good luck!
Posted on Aug 10, 2008
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast enough.it could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace it.to get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 22422 Top Load Washer Logo
146 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
