Question about Maytag Atlantis MAV6451 Top Load Washer
Atlantis Mav6451AWW washer just fill and does nothing else. won't spin or drain
  • Anonymous Sep 22, 2008
    washer does not spin dry enough clothes are to soaked when spin cycle
    is done
  • aloenen Sep 28, 2008
    Same problem.my Maytag washer will not spin. Clothes are still soaked. I have noticed that once it finishes the rinse cycle, and I "open" the lid, it seems to spin ok.
Washer_tech
  • 164 Answers
SOURCE: Maytag Atlantis MAV6451AWW
turn off the water and remove the hoses from both the wall and from the back of the machine. check the screens inside of the machines water valve, they are probably clogged. do the same for the hose screens on the other end. replace the hose screens at the wall end and remove the screens from inside the machine. replace hoses and turn the water on and you should be good to go
Posted on Sep 20, 2007
  • 4 Answers
SOURCE: Mayatag Atlantis Top Loader Washer Model MAV6451AWW
there are two clips about 3 inches in from the corners in the front between the top and front panel.you push a putty knife into the space between the top and front panel about 3in in from corners and lift the front of the top.
Posted on May 12, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
  • 20 Answers
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
Posted on Feb 20, 2009
Mav6451aww will not spin
Does washer fill, wash and drain? This washer is a straight forward unit and that complicated like new front loads. If unit fills, wash and drain, then I would lean toward a timer issue. With the unit filling, washing and draining, that tells me lid switch is good, motor runs in wash direction, pressure switch is working and tub is not locked down. Also, if motor turns one way, then motor is good. If unit is not doing the three things, then could be lid switch, pressure switch or bad motor.
May 12, 2016 | Maytag Washing Machines
Maytag mav6451aww squeals loudly during spin cycle
The squeal you here is from the drain pump going out. I have replaced so many of these it's not funny. The new pumps are redesigned. All you need to do is remove the belt from the bottom, open the access panel on the rear left side (as you look at from the rear), remove the three bolts and pull the pump out. put the new one on in the reverse order. Here is the new pump.
Oct 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will not drain or spin out.
look underneath is the belt attached? if so then there is something in the hose from the tub to the pump.
Apr 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Sep 19, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
