Question about Garmin GPS
We live in a Rural setting just outside of Saskatoon, Sask, Canada. Intersection are marked as [an Example Township 382 Range Road 3043-A]. I haven't been able to find anyone that can enter an address like that for rural seaches. Even those that have GPS system don't find this one very user friendly
  • fast242 Aug 01, 2008
    absolutly of NO value.But what did learn was that I got sucked in to pay for something at is of NO value. Rather than saying the rural Twp - rge map find is not part of the GPS system search..I've also learned that others that own more costly units and thay also can't do the rural search. So why wasn't I told up front rather than paying? Thanks for the shafting you gave me. Ernie
  • 2,071 Answers
Have you tried resetting the unit?
Hope this may help;
Regards,
VOTIT
Posted on Jul 28, 2008
    Genius:
  • 2,035 Answers
Please mention GPS model number and make ....
What is the average of the numbers 37 76 92 96 81
You've got five (5) numbers to average.
First you add them together:
37+76+92+96+81=382
Then you divide that by the number of numbers you started with:
382 divided by 5 is 76.4.
Why does this work?
Imagine you had a stick 382" long and you wanted to divide it into 5 equal parts. Easy enough, you just divide the length by 5. But what if you didn't know the stick was 382" long? And what if you only had an 8' tape measure (96")?
One way is to measure off several lengths that are within the range of your tape measure and put a pencil mark at each length, then add up all the lengths.
So, if you put a pencil mark at 81" from one end of the stick, and then another pencil mark 76" from the first mark, then another pencil mark 92" from that mark, then another mark 96" from that mark, you'd find out that the last mark was only 37" from the other end of the really long stick.
So, you'd add all those measured lengths up to get the total length which is 382". But you don't want different lengths, you want equal (or average) lengths. So you divide the total length by 5.
Mar 16, 2015 | math.com Computers & Internet
Where would I go to get our pressure washer serviced? I live in the Saskatoon, Sask. surrounding area.
Does the electric motor keep running? If it does continue to run with the trigger in the spraying position, then your pressure switch and motor are OK. If the motor is running and the water is not coming out with pressure, then either your check valves are not closing properly or the pumping mechanism is in need of repair. I think those little electrics have a simple wobble plate design. Basically not worth the effort to fix them
Oct 09, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
L need to order two switches for heating element, Canalta in Moosomin, Sask 306-435-3034
Harland Fairbanks in Saskatoon should be able to help you.http://www.harlans.ca/locations.html
Jan 23, 2013 | Cretors 6 oz. Goldrush Red Top Popcorn...
2005 sgv, when its cold outside the starter drags,when it is in warm parking its fine. I live in edmonton ab canada is it a moisture problem? It has a brand new battery
Have the chargeing system check out on it, It is probally a problem with the starter ,They donot last for ever ,No matter where you live, End i live in Regina ,Sask. For over 40 years, Moisture has nothing to do with it,
Dec 07, 2012 | 2005 Suzuki Grand Vitara
When I graph system of linear equations and try to find an intersection point it says no sign change why?
The solve( function was not able to find the intersection point because it lies outside the graph range. The window dimensions are too narrow to contain that point. I suggest you restrict the graph to the quadrant where you suspect the solution to be (example first quadrant if appropriate) : take Xmin=0, Ymin =0 and choose Xmax and Ymax large enough to enclose the intersection point.
Sep 11, 2011 | Texas Instruments TI-84 Plus Silver...
I LIVE IN CANADA AND I HAVE A GARMIN NUVI 670 WITH PRE LOADED MAPS. I HAVE FOLLOWED DIFFERENT ROUTES AND SOME HAVE TAKEN ME TO AREAS WITH DEAD ENDS BRIDGES OUT ETC. CAN YOU TELL ME WHAT IS THE BEST ROAD...
I go to New Brunswick area Shediac, Moncton had no problems yet...
Look and see what you Navigation set to. to do that go to Tools...
Settings....Navigation
under Route Preference I set it to Faster Time .. you can click it to change to Shorter Distance or Off Road
On avoidances... I have it Enable.....Click it to change what to avoid..
I have checked mark U-Turns....Traffic...Car Pool Lanes and Unpaved Roads.
Hope this helps
Love my Nuvi760
Sep 21, 2010 | Garmin Nuvi 660 GPS Receiver
Will not properly display rural areas near Greenwood,Nova Scotia ,Canada postal code b0p1n0
If you have the most updated maps installed the only other option I can tell you to try is making sure that all your avoidances are selected properly. Usually by default your avoidances are set so they don't recognize things like rural roads, toll roads, dirt/farm roads for fastest directions and speed. Look into this and see if your adviodances are turned on. If so then turn them off and see if your roads are there. If it doesn't work then you will need to connect your garmin to the PC and run an update to see if you have the latest map update.
Hope this helps
TankMurdock
Apr 14, 2009 | Garmin Nuvi 350 Car GPS Receiver
Reparation of bushnell Model 78-4678
Looking for a service department.
Sep 11, 2008 | Optics
Rural addresses - Township & Range roads
With the Garmin Mapsource program just type in the name of the road and search. It shows up, and it's not saskatoon but corman park, although near to saskatoon, it's actually in a different area. This also happens when cities grow and small rural area's become part of the bigger picture, it's stil located where it historically was...looking for places can be sort of tedious. If I need to go somewhere, If i can't find it I ask for coördinates...the other way of getting there...A friend of mine lives on kitely line near jasper in Ont. the GPS knows the place as Line 3...huh?
Jul 28, 2008 | GPS
GPS Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
