Question about Singer 7442 Mechanical Sewing Machine
Singer FM22c bobbin case pops out of position when sewing. It does not stay latched.
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 51 Answers
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Posted on Sep 06, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
  • 6 Answers
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
How do I get the empty bobbin out of bobbin case. Singer sewing machine
Most bobbin cases have a release latch that allows the bobbin to drop out of the bobbin case. In the following link, it is the flat lever with the hole in the center that extends across the entire width of the bobbin case--it just lifts up. The other projection is the finger.
Singer Bobbin Case
Mar 11, 2017 | Singer Sewing Machines
I have a Singer Touch and Sew #758. The bobbin case keeps popping out of possition when I try to sew. I have cleaned and oiled the machine, checked all the threading, tried different bobbins, etc. The...
it does sound as if the sprung bracket is not holding the case in position. Move the latch to the right, remove and install the case and then move the retainer back into its proper position
Feb 17, 2014 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Bobbin case pops out
Are you sure it is the correct bobbin case ? If it is check the spindle it slides onto and make sure there is not a bit of lint or cotton on there, this will cause it to not engage the locking latch correctly. Also is the bobbin is not the correct one, or is bent it will not lock in correctly. The other thing to do is put a drop of oild on the spindle the bobbin case slides onto.
Jul 01, 2009 | Singer 7422
I just purchase a Singer 301 and cant get the bobbin case out
Raise the bed extension, revealing the bobbin area. Gently pull out on the bobbin case latch and it should pop right out in your hand. Congrats on your 301, they are wonderful machines!
Jun 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Mar 17, 2009 | Singer Featherweight 132Q Mechanical...
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
148 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
