Question about Toshiba Satellite 2060CDS Notebook
Won't boot up
I turn it on and windows 95 comes up but it gos to a page error #0
  • Toshiba Master
  • 2,794 Answers
Turn the computer off. Turn it back on and press f8 at the beginning of the boot process. This should display a menu on the screen. Select safe mode. and see if the comptuer will boot up. If that doesn't work the operating system will have to be reloaded.
Posted on Jul 27, 2008
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
WINDOWS 7 WON'T RELOAD
Before reloading Use a system utility tool like Reginout for an instant fix.
Apr 13, 2012 | Apevia Computers & Internet
Hello All. I am having problems starting my computer which runs Microsoft Windows Vista Ultimate, and the boot.ini got corrupted. #Is there any way that i can fix this. That is the only problem why i...
Glad to HELP YOU!
You have two solutions to fix that problem:
1. Build-up a boot.ini by yourself
Go in the root of your C:\ drive and save your initial boot.ini as "_boot.ini"; now open NOTEPAD and write there:
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows Vista Ultimate" /fastdetect
Select SAVE AS and give it the boot.ini name. Put it in the root of your C:\ and REBOOT
2. If the above mentioned doesn't work here's the second solution: download and install on your system a software called SystemSuite Professional (I think now it's the version 11...). You can find it here. This software will help you to fix MANY of your machine problems, not only the boot.ini errors. Just scroll down the page to read what it is capable to do...
GOOD LUCK!
Mar 29, 2011 | Microsoft Windows Vista Ultimate Edition
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
I turn on my hp pavilion zd7020us the hp page boots up then goes to safe mode or normal mode page then goes to a very quick blue screen and turns off and starts the whole process over again any ideas
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 18, 2010 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Booting error
What I would do is take the hard drive (1) out of that machine and put into an another pc - xp would be fine. Now go to the root of harddrive (1) and edit the boot.ini file. you will see an entry similar to this ......
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
All you need to do is make sure you know which disk you're using (c drive is 0 usually) and the partition should be set to 1 for regular installations.
Did you add any drives lately? or make any changes to your OS?
Jun 14, 2008 | Microsoft Windows Server Standard 2003 for...
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Toshiba Satellite 2060CDS Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
