Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Electrolux model 2100
I need a parts list and wiring diagram
  • valleli Aug 22, 2008
    Need wiring schematic for the ultralux.
The power nozzle is equipped with a automatic shut off if something gets jammed inside it. Try resetting the button on top of the power nozzle after making sure the brush still rotates freely. A broken drive belt may also be the problem. You'll need to open up the power nozzle to check the belt. Pay attention to the screws as you take them out. One of them is shorter and is made to go into a specific slot.
Posted on Jun 22, 2009
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
Shuts off (overheats) after 10 minutes. Protecto relay? How to take apart?
Your machine is what's called a "Special Model" and needs to be disassembled upside down in a form fitting tray, by removing the two side rubber bumpers, then taking off the bottom and finding the part that shuts it down. The best thing to do is to take it to an Electrolux repair shop and let them handle it. They have the trays and they're trained in the way it comes apart properly;
Nov 09, 2013 | Electrolux electric hose models 2100
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
I would like to download a manual for an Electrolux 2100 vacuum cleaner.
Go to http://www.aerusvacuums.com/support/manuals/.
Go to "Older Models" and click on 2100. Click on "download". Save to appropriate file.
Dec 20, 2010 | Electrolux Vacuums
I need a new power cord for the power nozzle on my Electrolux 2100 canister vacuum. The power nozzle has part number N115M written on the bottom. I have found the power cord for power nozzles PN6 and PN7...
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
http://www.aerushome.com/storelocator/
Dec 12, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I need a price for a wand for my electrolux ambassador 2100 vacuum cleaner
This same wand is used on all older canister models since 1974 until about 1995.
Metal wand, about $24.
Upper wand assembly, about $34.
Parts should be available at any Aerus shop.
Of course, you can try to find used ones, often with complete vacuum, at second hand stores, pawn shops, yard sales, estate sales, etc.
Sep 29, 2009 | Electrolux Vacuums
I'm looking for a used or reasonable priced motor for my Electrolux LE, series 2100 vacuum. LEE is shown as model but no searches respond to this as a model number. Help. Thanks, Max
Unfortunately, the Electrolux company as such no longer exists. Eureka bought the name "Electrolux" and started making Eurekas with Electrolux stickers on the outside. This makes for some confusion when looking for parts.
The company that used to make Electrolux is called Aerus, and they may still be manufacturing parts for those machines, but true Electrolux parts are getting scarce. I'd check the Aerus website and see if they have a way to get those parts, or at least a cross-reference.
-R
Aug 16, 2008 | Electrolux Vacuums
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
701 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
