Question about HP Compaq Evo Notebook N410c
Touchpad problem Now I think about it the touchpad was working fine until I ran a Windows XP update, after which it ceased to respond. I have a mouse, but as I only have one USB port it makes life difficult if I want to print etc! Can I take the computer back to before I ran the update? Bob
    Sergeant:
  • 310 Answers
Hey, you can uninstall any update by windows, just go into control panel, add/remove programs, and theres a box at the top that says updates if u put a tick in it, you will see a list of windows updates that have been installed, just click on it and remove any you wish, if you check control panel, system and device manager for any red or yellow tags as this means a problem with a piece of hardware and needs drivers reinstalled, if no red or yellow tag shouldnt be any problems, if it does go to your laptops manufactors website and download the driver again...
Hopefully get you sorted this time :-)
All the best
John
Posted on Jul 28, 2008
Touchpad too sensitive
In the Windows Control Panel, select 'Mouse'. It allows you to change the speed at which the mouse responds to the touchpad. Lower the setting until the touchpad has the desired sensitivity.
Jan 24, 2013 | Gateway Computers & Internet
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
MOUSE PROBLEM
run a virus checker through i had the same problem with the moving mouse thought i had a good virus checker but somehow it got through hope this helps regards Jim
Apr 23, 2009 | Computers & Internet
I have a Compaq C700 and the touchpad and keyboard are not responding. What should I do?
Check if the touchpad be disabled from BIOS;
See if it still same if you use USB keyboard and mouse?
Try update BIOS from HP web.
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
HP Compaq Evo Notebook N410c Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
