Problem with tefal quick cup, has started to mix hot and cold water when you try to get a cup of hot water
  • 143 Answers
Very strange problem for an air conditioner. I think you've posted this is the wrong category.
Posted on Jul 27, 2008
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Lost instructions
I have found my instructions.
You press both cold and hot button down for five seconds until blue light appears. Bingo!
Mar 13, 2009 | Kitchen Appliances - Others
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal quick cup- no longer heats water well
press red button 4 times quickly should reset & poor between 85- 92 deg
Jan 31, 2009 | GPS
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal Quick Cup not heating water
press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Dec 15, 2008 | Kitchen Appliances - Others
Water is not coming out hot enough for coffe or tea from my tefal quick cup
It won't be hot it's like tap water. Did you see the drain for the furnace?
Nov 25, 2008 | Heating & Cooling
Tefal Quick Cup not working
This is in my opinion a design problem. The wiring connects to the spiral heating element via spring loaded contacts which only have a tiny connection surface area. These gets arcing deposits on the surfaces and will periodically require scraping clean. To get access prise off the silver top assembly which is a snap fit, unclip the circuit board and pull the plastic water pipe off the top of the plastic cylindrical tank. Then remove the two star screws from the base and prise it free. The whole internal assembly can now be carefully removed intact from the kettle housing but the circuit board at the top will need to be turned vertically and guided down the main body on the way out.
Jun 04, 2008 | Kitchen Appliances - Others
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
