Question about Sony Handycam DCR-TRV350 Digital Camcorder
Sony camcorder Screen is black like if the lens are closed, won't record...Also you can't view recorded tapes but has sound
  • Sony Master
  • 2,794 Answers
Pick up an 8mm tape cleaner and see if that does the trick.
Posted on Jul 27, 2008
I have sound and can view previously recorded videos on my camcorder. However, on Christmas morning my camera doesn't record or view images. It just records a black screen with white lines. The li
The recording head is probably the source of the problem and will need to be replaced, other than putting a dry cleaning tape or better still a new blank tape, allow it to play right through, it may work.
Mar 10, 2012 | Sony Handycam DCR-DVD105 DVD Camcorder
When i go to record you can not see anything thru the window or the viewer but it records the voices. the viewer is all black. and the lense cover is off. you can view any previous tapes that have been...
Sounds like a sensor problem - which happened recently to one of my own video cameras Called Sony, and they are replacing the lens and sensors and refurbishing the camera to like-new condition. Here is the number as listed on the Sony website: Priority Service Line (for U.S. only): 239-768-7547. Once through the maze of recorded menu options, and you get to Camcorder Repair service department, they will help you very efficiently. Hope this helps.
May 17, 2011 | Sony Handycam DCR-TRV265E Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Screen black. Everything else works perfectly.
To my understanding that you do not see live view in camera mode to record and camcorder playback old recorded tapes correctly and you get picture in LCD.
If it is true then please check lens cover that need to be slide down to get live view in camera mode. If problem still exist then 2 possibilities, either aperture in lens mechanism is bad or ccd imager is defective.
In that problem, camcorder needs qualified tech to fix it.
Let me know any further query.
Nov 03, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Erasing the tape on a sony handycam vision please
Well the cheapest way is to go into record mode, cap the lens with the black lens cap and record a 'black' picture on the tape. This will erase all the pictures on the tape and leave you with a 'black' screen on the whole tape.
Oct 05, 2009 | Sony Handycam CCD-TRV37 Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Problem with camcorder
See if the tape heads need to be cleaned by using an 8mm tape cleaner.
Jul 27, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Black screen
it's a bad ribbon to the ccd have to send in pretty common problem
Oct 25, 2007 | Sony Handycam CCD-TRV608 Camcorder
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
49 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
