Question about Olympus FE-110 Digital Camera
Same problem shook it checked batteries,voltage good and inserted properly repowered up; lens came out, no lcd view,lens eventually went back in after trying to power off several times. now having original problem again thanks, freshham
  • freshham Jul 27, 2008
    any more suggestions ??
    Genius:
  • 3,422 Answers
If the lens does not extend then it is possible that it has become jammed. Sometimes this can cause the camera to sense an error and shut itself down immediately after powering on.There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly.
IF you are not getting a display on your LCD then it is a CCD sensor issue.There are no home remedies for this problem and you will have to get it repaired.
Posted on Jul 28, 2008
OBJECT ERROR RESTART CAMERA
If you did not obstruct the lens, would think there is a battery problem. Digital cameras require lots of power. As you call on it to do more things like extending the lens and focusing the power requirement goes up.
I had a similar problem with my camera and finally discovered that the problem was with the battery to camera electrical connections. I cleaned the contacts as described in the source link about two months ago and have not had a problem since.
The following excerpts came from the source link. Hope this helps!
Most cameras will reset to original settings if batteries are removed for at least one minute. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
The secret to making digital cameras work better is having good electrical contacts between the batteries and the camera.
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out.
To prevent overcharge, use an automatic two or more hour battery charger with safety timer, temperature monitor and trickle charge technology ($9.78). For longer life, NiMH batteries should be charged often and kept in active use. To preserve battery charge, use the view finder and not the LCD display when possible. Maximum capacity is reached after 2 to 4 charge/discharge cycles.
http://www.google.com/base/a/4210404/D13...
Mar 13, 2011 | Canon PowerShot SX100 IS Digital Camera
A few weeks ago my 97 cherokee's check guage came on. Voltage dropped to zero and then eventually drained battery. I removed altenator and had it tested. It tested ok and I reinstalled. When I started it...
Hello, Yes it sounds as if it is a computer problem. There is no way to bypass it you will have to replace the engine computer. Good luck and feel free to ask anymore questions about this and I will do my best to answer them.
Jan 29, 2011 | 1997 Jeep Cherokee Country
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Lens is stuck
Most cameras will reset or restore to original settings if batteries are removed for at least one minute.
Clean, charge, and insert batteries again then restart the camera. Remove extra memory to eliminate this as a possible camera problem.
Electrical contacts in the camera and on the batteries must be cleaned properly. Digital cameras are high drain devices. Batteries may have a full charge, but will be viewed by the camera as low if electrical contacts are not really good.
Check out the source link for more helpful information on cleaning battery and camera contacts. Source(s): http://www.google.com/base/a/4210404/D13...
Jul 03, 2009 | Kodak Easyshare 1725043 M893Is Digital...
It just shut off....
it normally indicates a problem with the batteries. Try inserting disposable alkaline battieres in the camera and turn it on.
If the lense is still out at the moment try pressing the play button the back of the camera to view the pictures taken, even with a very low battery this normally close the lense properly and enables you to view the pictures.
Nov 15, 2008 | Kodak EasyShare C613 Digital Camera
Lens error - stuck half open
just check the power of battery ........ if it is ok just remove the battery .........clean the battery contacts properly and once again insert the battery ............then power on this will remove your problem
Jul 23, 2008 | Nikon COOLPIX L3 Digital Camera
No image on lcd screen
sounds like your lcd went out. you will have to send it in to have to fixed.
Aug 18, 2007 | Casio Exilim EX-Z750 Digital Camera
When turned on, lens goes out then right back in, eventually camera shuts off. view mode OK.
This might be an E18 lens error issue. Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 04, 2006 | Canon PowerShot A75 Digital Camera
Olympus FE-110 Digital Camera Logo
75 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
