Question about Lands Phones
I have three Motorola 78503 that no longer connect with the chargers? any ideadas? The chargers work with other pnones and the batteries can be charged with other pnones. The connection just does not seem to work.a
  • Anonymous Oct 07, 2008
    hey i had this phone. I gave up on it because the charge port over time would be off. Like it would be adjar so to speak. I would have to rig up a system where i would tweak it so the connections matched up in the phone properly. IE pushed up and down on the actual male charge piece. I remember actually setting it up with a brace like a pack of smokes so it had the perfect angle for the female piece inside the phone.
  • Anonymous Apr 11, 2009
    I had a phone like that too. I think this problem is just one of many that starts before this phone gives out completely. Mine started out with the same issues that you had and then it started doing this thing where when you pressed the menu options it would take about a minute or so for them to come up, then the video card went out and just shows a white screen, so I had to get a new phone. If you have something on there that you'd like to keep, save it now or it will be lost.
People might buy parts for this old phone. i still have mine, even though it's starting to fall apart, I like it that much!
Posted on Jul 01, 2009
Screen is black all the time, can't turn phone on or off
1) Is your charger / adapter working OK ?
Most of the time, an adatper or charger contains a red or green LED, showing it's active, when inserted in the wall-outlet (110 / 240 V AC). In some cases, this LED will emit light, only when the mobile phone is connected.
If this doesn't happen, you might consider buying a new(er) charger for your mobile phone.
2) Is battery charged ?
No further discussion / c;arification needed.
3) Does phone contain an old(er) battery ?
If the mobile phone is used for a longer time or used intensely, the battery might be "worn out". A battery is able to be charged, but will show it's limits, because of it's maximum usage. With this I mean, they can be charged a maximum amount of times. If you even use a quick-charger, the battery may suffer more, resulting in a less longer lifetime. In such case you can replace your battery, by simply ordering / buying a new battery for your mobile phone.
Sep 03, 2013 | Motorola Mobility RAZR V3
Where can i buy batterry and charger of motorola i550 plus?
The battery is readily available online or through any Motorola 2-way radio dealer. You can use part number NTN8971 or NNTN4190 NiMH battery. The phone should also accommodate 4 AA batteries instead of the NiMH battery. (Be certain to never try charging the phone with the AA batteries inside, as it is not designed to do this.)
The wall charger part number NTN1680 is listed as being no longer available from Motorola Solutions. However, during a Google search it appears several vendors still have these available for just over $7 US dollars.
The i550 was a primary phone used in the iDEN Nextel system. It operates on 800 MHz and likely needs to be connected to a system to work. I do not know if it will work as a 2-way radio without being connected to a system. The type of system these were used on has been completely or for the most part shut down. According to this article it will be completely shut down by June 2013. http://www.computerworld.com/s/article/9227557/Sprint_to_shut_down_Nextel_iDEN_network_next_year
Here is a link to the user manual for the i550 http://www.cellphones.ca/upload/manuals/motorola_i550plus.pdf
Best regards.
Sep 21, 2012 | Nextel Motorola i550 plus cell phone w/...
Battery will not charge
There are only three likely solutions.
1. The charge port on your phone is broken (Most likely)
2. The battery has reached a thermal cutoff and will no longer accept a charge.
3. The charger cable is bad.
If you can try another battery or put that battery into another phone you can isolate that problem. If you can charge something else with your charger then your charger workers.
If that still doesn't work then plug the charger into your phone and lightly press on the charger. If your phone springs to life it means the charge port is likely suffering from a poor connection. If this is the case then sadly there is nothing you can do unless you're very good at soldering.
Jul 24, 2012 | Cell Phones
Motorola batt charger
The charging unit may have monitoring circuit on each slots to switch the charging current to trickly charge to prevent over charging the battery.
Apr 19, 2012 | Motorola T8500 Two Way Radio
It doesn't come on, it needs flashing,how do i do it
either you have a dead battery,,,or possibly your charger isn't working properly.
May 15, 2010 | Motorola Mobility RAZR V3
My mobility scooter batteries are put on charge but the charger green light to indicate that they are chaged no longer lights up
hi, now that could be one of three problems,
1. first check the charger ,is it possible to try the charger on another scooter ?
2. The batteries will no longer accept a charge ,this creates a fault condition with the charger. (try these batteries on another scooter if possible).
3. the actual charger plug in, you need to check the pins here , just the outside ones with a electrical meter, no voltage implies a bad connection to the batteries.
Regards
GeWiz
Please rate this reply.
Apr 22, 2010 | RTO Mobil Line Mobility Scooter Chair...
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Battery won't charge. Charger works on other Motorola phones.
More than likely the battery is done for...
I myself have so many phones that have batteries that will no longer charge or much less retain a 5 minute charge due to them being on ice for the longest time.
Best bet is to replace the battery with a new/used one.
Mar 15, 2009 | Motorola Mobility RAZR V3
Lands Phones Logo
1,152 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
