Question about Whirlpool LSR7333 Top Load Washer
LSR7233DQ1 washer will agitate good with load but will not spin with load. any help. thanks
  • dgardner Jul 29, 2008
    MAYBE I SHOULD HAVE SAID THE MOTOR IS RUNNING DURING SPIN CYCLE ALSO. COULD IT BE THE CLUTCH???
  • dgardner Jul 30, 2008
    the coupler seems to be fine and in tack. thanks anymore ideas?
    Genius:
  • 1,198 Answers
Check your lid switch, it can be bypassed until you can get a new one. Just be aware that the machine will agitate and spin with the lid up. To open the top use a putty knife or butter knife at the joint of the top and bottom at the front corners to push the catch in while lifting the top. On an older machine the lid switch goes bad, another thing is the rubber drive part between the motor and the transmission, but the machine probably wouldn't agitate either.
Posted on Jul 29, 2008
  • mike kirschbaum
    mike kirschbaum Jul 30, 2008
    Right between the motor and the transmission is a rubber drive member. It has bumps that shear off. It's usually pretty easy to pop off the clamps that hold the motor. It's been a while since I've done this job, but remember it being easy.
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool ultimate care II agitator seems as if it is not woking properly
this is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
Jan 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 weak spin and agitation, good coupler,
go to www.searspartsdirect.com put in you model number and you can pull up a explode view of the transmission.
Apr 13, 2010 | Kenmore 15864/15862 Top Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
My kenmore washer 70 series model 20712 990 will not agitate or spin. it drains, but won't agitate or spin. what is the problem?
This model has a safety switch in the door switch. This switch goes bad and the machine will not spin or agitate. Have that replaced and you will be back in business. Hope this helped you out. Good luck.
Jun 05, 2009 | Kenmore 24032\24036 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Machine does not spin, clothes are soaked
fill washer and make sure it agitates. If it does not agitate but can here motor running you have a bad motor coupling. If it agitates but wont spin make sure lid switch is good, if good you have a bad gearcase.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator problem
Check to make sure connection by motor are good sometimes one phase of the motor will go bad that might be the case try the selector switch for agitator speed on different settings
Jul 11, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
291 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
