Question about Linksys Wireless-G WRT54G Router
Router/ modem I,m looking to replace wireless-G cable gateway. I want to replace with an "N" and make sure it is capable for 20 meg speed on a cable broadband connection. All I can find so far is the router. I wanted to stick with the modem with router is that still possible in the "N" or do I need to do something different? Libby
  • Libsnps Jul 27, 2008
    MODEM CAN'T HANDLE SPEED THATS MY PROBLEM. I TESTED ALREADY. I SHOULD BE GETTING A 20 AND I'M ONLY GETTING 8
  • 2,794 Answers
Your modem shouldn't need to be replaced unless your modem isn't handling 20 mb speed. You could update it to a newer modem the is running DOCSYS if your cable modem hasn't been replaced in awhile.
You can test your connection by going to this website
Check with your cable provider and see if your line is setup for that speed already.
Posted on Jul 27, 2008
  • Tim Babcock
    Tim Babcock Jul 27, 2008
    Thats only what the modem is rated but there aren't any guarantees that you are going to be getting that speed all the time. You will have to check with your provider on that. I know I have to pay extra on my Comcast service just to get 8 mb.
    They could even swap out the modem for you.
The range and speed coming from the router isn't great considering how much we are getting in and paying for. Anything we can do or is this the routers maximum capacity?
Depends on the router. Many routers will never handle the alleged speeds you get from the cable or U-Verse as far as the wireless goes. And, the device you are using is more limited than the router. If you go to one of the broadband test sites and check your internet speed, that shows the speed of the modem. If you have an integrated modem and router, you would still not likely get the same speed throughput from the wireless side. 15 Meg's on wireless is pretty fast.
Sep 12, 2014 | Computers & Internet
How to set up the wireless internet connect on my laptop to this new SBG901 modem?
Short answer: YOU DO NOT.
The cable-modem just converts from the cable-company's signals to/from Ethernet signals.
You use an Ethernet cable to connect the output from the cable-modem to the 'WAN' (or 'Internet') port on a router with wireless capabilities. Then, you configure the router to create your own wireless network, with:
* an SSID ("network name")
* encryption level (use: WPA)
* a password for your network
Then, your wireless device can cite the SSID/password to authenticate to the router.
Feb 24, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
How to set up my router to get speed by ISP? I have 80/25Mb/sec speed. The router access only 15/15Mb/sec.
Are you measuring while using an Ethernet cable between your computer and your router, or while using your "wireless" adapter to wirelessly connect to the router?
Re-cable your system, to temporarily connect your computer directly to the cable-modem, bypassing the router, and then measure the speed. If it still is "low", then telephone your ISP, and get them to trouble-shoot.
Otherwise, the router is capable of receiving at up to 100Mbit/second, and its "wired" ports are capable of sending to your computer at up to 100Mbit/second.
Does your computer have a "Wireless-G" (54Mbits/second) or a "Wireless-N" (more than 108Mbits/second) network-adapter?
Feb 19, 2011 | Linksys WRVS4400N Wireless Router
I only have one PC in my house and it's not in the same room where the cable outlet is located. Right now I have a very long coax cable running from my cable modem to the cable outlet in the other room. Is...
Purchase either a USB stick that adds wireless capability to your laptop/desktop, or purchase a PCI wireless adapter-card for your desktop, and install it.
Then, you can move the cable-modem much closer to the cable-outlet, and then connect the cable-modem to a newly-purchased wireless-router ($20 to $70) to receive/transmit over your in-home wireless network.
Jan 24, 2010 | Gateway GT5654 Desktop PC
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Want to get more speed out o my fiberoptic broadand
Well the best router for your connection type would be WNR2000. Even Virgin media recommend this router for their 20 and 50 Meg connection. I am pretty confident that this router will meet your requirement with this ISP connection.
Hope this helps.
Oct 12, 2009 | NetGear WGR614 Wireless Router
Wireless adapter
Go for an external USB wireless adapter, and the speed may vary depending on barriers and the distance from the router, the max. distance is about 30 ft from the router.
Tell me if anything else you want to know abt the wireless connection?
Askari :)
Mar 28, 2009 | Dell Dimension 8400 PC Desktop
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Can only connect to LAN, no internet access
Check for a vaild gateway address on router,start.run.cmd> type in ipconfig.if you dont have a valid ip or gatway. try a powercycle,turn off modem and then router,wait about 10-20 sec and plug modem back in. check your ip and gateway check for a connection, if that dont work call netgear to see if u have a defaulted router, or take it back for new one if u still have a recicpt.
Feb 06, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
