Question about Kenmore Elite 45986 Front Load Washer
Fabric softener should fabric softener run out as soon as you fill the resivor of a kenmore h3 font load washer
The softener should not run out as soon as you fill the reservoir.  If too much liquid is added to the reservoir, it will auto siphon into the tub.  Is your washer level front to back and side to side?
Posted on Aug 07, 2008
    Sniper:
  • 68 Answers
Most brands the fabric softener runs out during the filling of the tub.
Posted on Jul 28, 2008
The softer tray will not drain
Front Load Washer Troubleshooting: Clogged Dispenser ...
? 1:13
https://www.youtube.com/watch?v=KqQcyprw8j8
Dec 14, 2009 - Uploaded by ManageMyLife
Can you shed some light on why these aren't draining? ... Thosecompartment will stay filled with water after wash cycle. ...Whirlpool & Kenmore Washer Repair - Fabric Softener is NotDispensing - GHW9400PW1 - Duration: ...
Fabric Softener is Not Dispensing - GHW9400PW1 - YouTube
Nov 28, 2015 | LG WM2240CW Washer
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Our Kenmore HE 2Plus Front Load washer model # 110.475*4753 is haveing an F03 Error and we can not get it cleared. Any ideas? We have hit stop twice, and cleaned the hoses, nothing clogging them..help
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 13, 2010 | Kenmore Elite 45986 Front Load Washer
Describe your Kenmore 3.8 cu. ft. HE3 King Size Capacity Plus Front Load Washer Problem: F03 error message. Not clogged - anything else we can do?
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a front load Kenmore HE3T washer that is beeping and flashing a F3 code. I cannot get the machine to shut off with the pause/cancel button and had to unplug it...can anyone help me. Thanks
Aug 29, 2009 | Kenmore Elite 45986 Front Load Washer
Code F3 displayed and it won't begin cycle.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 03, 2009 | Kenmore Elite 45986 Front Load Washer
Put fabric softener in the soap dispenser
Just run the load. You can always re-wash.
Mar 30, 2009 | Kenmore Washing Machines
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Kenmore 3.5 super capacity front load washer won't dispense fabric softener
Kenmore 110 front load washer wil not dispense fabric softner. Code 21. Have already checked pump and filter obstructions
Oct 10, 2008 | Washing Machines
Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Sep 03, 2006 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
278 people viewed this question
Sal De
fordexpert
Robert Rankin
