Question about Microwave Ovens
The enamel on the frount where the microwave door and the metel contact has chiped off when the microwave is in use it sparks making unsafe to use how would i cover the metel spot so that the microwave will be usable
  • Microwave Ovens Master
  • 8,973 Answers
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
My microwave is about 7 years old and has recently started sparking when I heat things in it. Can it be saved or is it best to buy a new one?
sparking usually relates to i) using metal in the cavity or ii) some burnt food on the roof iii) the waveguide cover 'mica' panel is burning iv) door area enamel has been damaged. After 7 years you may want to bin it and get a new one as they are now so cheap, fixing them is usually more expensive.
Apr 22, 2011 | Dacor DMO24SS Microwave Oven
When i turn the microwave on it has electrical short it is like there is something metal inside and everything still works what causes the electical flash
The interior of the microwave is insulated with an industrial white enamel paint to prevent the magnetron from arcing on the inside, some of the enamel has worn off exposing metal,or the magnetron is shorting, either way this is very unsafe to use and should be checked quickly, and left unplugged in the process.
Mar 11, 2011 | Frigidaire PLMV169DC Microwave Oven
Problem with the Whirlpool GH5184XPQ 1100 Watts Microwave Oven: In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door an acrid burning...
The problem is that the magnetron is arcing when it is running and it has found a couple bare spots 'exposing the metal'. The microwave uses a special industrial white enamel paint to prevent arcing, it is very important that the oven be removed from service until the situation is rectified otherwise there is a danger of shorting out the magnetron.
Feb 22, 2011 | Whirlpool GH5184XPQ Microwave Oven
In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door a burning odor was smelled. I also noticed a burned spot about a quarter inch in...
There is not any power in the door itself. However if the chassis has chipped paint or corrosion the RF from the microwaves magnetron will cause those bare metal areas to reflect the concentrated RF energy and cause sparking.
The only Whirlpool Microwaves that have been recalled, has a model number beginning with XC and had a green sticker on the bottom face area of the chassis where the door closed.
I have often been able to clean and paint the bare metal areas with the correct paint to stop the RF reflection sparks. Using the model number above it is white enamel "appliance paint" that you would use to paint the bare metal areas. A word to the wise.... do not sand outside the area to be painted. Otherwise you re-introduce your current problem post repair.
The model number you passed is missing the very last digit that would be from 0 to 7 (Eight models)
Thanks for choosing FixYa,
Kelly
Feb 21, 2011 | Whirlpool GH5184XPQ Microwave Oven
Microwave safety after repainting
Too generic...Did you use the high-temp appliance enamel recommended, or a spray...or worse?
Was the rust inside where it can contact food through the circulating air, or on the outer body?
First thought based on how I read the question: Never use that machine again...but that's based on the word "in" instead of "on my microwave".
If the rust was around the door frame, outside the seals, and you used an enamel (of course) then you may be OK...but...
Considering the fact that a cheap microwave is a drop in the bucket when compared to your family's health...Why risk it?
Mar 29, 2010 | Welbilt MR622W Microwave Oven
Paint chipping of the inside of door of my sylvania microwave . There is bare metal under the paint .You can see how this is an issue.The warrenty numbers in the product manual are all disconnected...
well apart from replacing the door if clean the old paint away then you can paint the door with an enamel paint the colour of your door but it must enamel paint or microwave paint gd luck
Oct 06, 2009 | Microwave Ovens
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Metal turntable's enamel chipped, so sparks fly.
Try Going To Your Local Hardware Store And Finding Enamel Repair.
It May Just Cook But I Hope It Doesn't.
Jan 05, 2009 | Sharp R-820B Convection/Microwave Oven
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
