Question about Canon PowerShot S1 IS Digital Camera
Dark view field
WHen we turn our camera on, there is no view field. You can not see out of the camera and the flash automatically pops up because there is not enough light. our guess is that the shutter is not opening.
It was working fine, nothing dropped, etc. we just changed batteries.
We can view pictures already taken, but can not take new ones - the result is a black screen/photo.
Please help?
  • outlook353 Aug 27, 2008
    View finder and lcd screen have no picture. The flash hasn't popped up for a long time but I can manaully mpop it up. The former problem is the bBIG concern
This camera has been recalled and will be repaired free of charge regardless of the warranty status.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9739&keycode=2112&id=48266
Posted on Aug 19, 2008
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
Nikon D3100 won't flash
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
Jan 12, 2014 | Nikon D3100 Digital Camera
My photos are coming out dark on my Nikon D5100...should I be using an additional flash? An extra one attached to the camera? Sometimes they look dark on the live view and come out okay after the picture...
The build in flash, will be useful within several meters (15 to 20 feet) if it is really dark.
Your camera should be capable of taking pictures in poor light conditions. Try to shoot in automatic mode. The mode dail to AUTO. (green camera symbol). Then view the picture with info. There you can see the ISO, Aperture and shutter time. From there you can experiment for darker or lighter pictures. For this you can choose M, A,S or P.
In each of these modes, you can use the following steps.
On top of the camera, close to the shutter release button you see a little knob with a +/- sign. If you press that button, you should see a 0.
If you see a - figure, this means the picture you shoot all be darker than normal. If you see a + sign with a figure it means the picture will be brighter. While pressing that button and turning the command dail, you can choose -3 to +3 EV. That is much darker and much brighter.
If you shoot many pictures in bad light conditions, you could buy an external flash. A Nikon flash will work very good and automatic, with your camera, because camera and flash will communicate and help each other to make better pictures. Cheaper external flashes can work too, but most of the time you must change settings manual on the flash. Never use old flashes, that were build for analog cameras. They sometimes switch with a voltage higher than your camera can handle. The camera can be damaged by such a flash.
Dec 04, 2013 | Cameras
HOW TO TURN ON FLASH
Flash should pop up automatically when you operate camera in easy mode (green square on dial selector) in low light conditions. If using in manual modes press the button on the left side of the lens mount. To fire the flash without taking a picture press the button used to zoom out when viewing pictures.
If your flash does not work at all then there is probably a fault with the charging circuit or firing circuit.
May 11, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
My flash wont work on the camera... i dont know how to turn it on. it is up but it doesnt flash. whats wrong??
The flash automatically pops up and strobes when the surrounding are dark. If it does not flash, make sure that you have selected the flash mode you want. If it is still not working, take it in for a service. If it is still under warranty, they will fix it for free.
Here is a link for the manual just in case you don't have one.
Thank you for using Fixya and your generous rating will be much appreciated.
Oct 20, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Flash
mcomijohns. WHAT ARE YOU SUGGESTING!!!! Stop.
Lakshmy Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it pop up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.) PLease let u shave more information for a proper solution.
Sep 26, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Keep getting err 05 stating that the flash is obstructed
does the flash pop up?
Try this in a dark room with the setting on automatic.
If it does NOT pop up, the problem is that the flash is stuck in some way. Try gently prying it up if you can. if not, take it into a camera repair shop to get it fixed.
Nov 18, 2008 | Canon EOS 40D Digital Camera
Flash
It may be broken/blown, but there is a way to toggle the flash. There is a button located on the left-front of the camera , just left of the flash and above the lens. Hold it while scrolling the wheel on the right.
Best way to find out if it's broke or not: put your camera on Auto, go into a dark room, and take a photo. If the flash pops up and takes a shot w/o firing, you know it's broke. If it doesn't pop up at ALL, you've probably got a bigger problem
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
FD95 flash problem!
The flash doesn't open automatically. There is a button on the side of the camera that says Flash (open).
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
