Question about Tomtom ONE 3rd Edition GPS
The data card keeps appearing on screen with a cross through it,does this mean it is corrupted
  • Guvi2k7 Aug 16, 2008
    we brought one new SD 4GB Data card so we can buy the westen Europe Map and we downloaded it and it appears as an x on the SD card when turning it on, it dose the same as the old card as well.
  • Anonymous Aug 17, 2008
    when you turn it on it his asking for memory card. it shows a blue card with a red x in it and wont go no further. tryed other cards and still the same. can you hellp me please.
The data card keeps appearing on screen with a cross through it,does this mean it is corrupted?
Posted on Dec 23, 2008
  • 515 Answers
No, it means that tomtom cant read the systemfiles.
See http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Posted on Jul 27, 2008
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
Memorycard unaccepted keeps haveing red cross
The card may not be properly formatted for this application, or the data file is corrupted.
The card contacts in the receiver may need to be cleaned.
Oct 03, 2012 | Tomtom ONE GPS Receiver
I am using my headphone but there is no sound at all. i tried checking the master volume in the control panel and its not on mute.
If your Master volume is mute or showing disable its mean your sound card driver is not installed properly. Please install your sound card driver properly. to intall your sound card driver properly please follow these steps
1. keep your system driver's CD in your cd rom
2. on desktop write click on my computer and select the last option of "Properties"
3. a new window will appear select the 3rd tab HARDWARE
4. and now select the first tab DEVICE MANAGER
5. now a new window will appeared on your screen in this screen you can see a mark on the sound driver cross X mark or question yellow mark ? its mean you have any problem in your sound card driver
6. now right click on mark and select update driver
7. select your cd rom and click on next
after installing finish button will appear click on that and restart your PC your sound is enable now.
Jul 16, 2011 | Computers & Internet
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
A "Protected card" message keeps
To format your card is a method of outputting data in a specific format. You can do that from the digital camera, in the menu look out for the Format option and use it, or you can plug it into a computer (through a card reader) and once it shows up in My Computer, right click on the drive letter and select format.
Dec 29, 2010 | Fuji Cameras
My tom tom is not working, when you switch it on, a screen appears with a picture of the tom tom and a pair of hands with a cross over them on top of a memory card, this image just keeps on repeating...
Try reseting it:<br /><br /> Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. The reset button is on the bottom<br /><br />(support.tomtom.com)<br />
Aug 20, 2010 | Tomtom ONE GPS Receiver
My monitor screen keeps turning off even when the
First open the Data cable (From AD card to Panel).If light comes means Inverter card is ok and AD card is bad..If not means Inverter card is bad and AD card is ok..If you want to repair the inverter card,pls replace all the Electrolytic capacitor and Enjoy..
Sep 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Tom tom go 510 won't go ............
I red cross usually indicates an SD card problem.
With most tomtom's usually removeing the SD card and powering up will resolve the issue.
If not then a HARD reset without the SD card may be called for.
If it does prove to be an SD card error then formatting in a proper card reader using FAT32 as the file system and then copying the files back over from the tomtom usually does the trick.
Or format and restore from a back up to the card. can work too.
It may also mean that a files might have been deleted or become corrupted.
Aug 29, 2009 | Tomtom Go Plus GPS Receiver
Screen keep appear 'memory low. delete some data'
just change your prefered storage to memory card...actually your selected memory is phone memory...so thats why every file received from bluetooth save in phone memory..to change your stroage go to messages ------> settings-------> change your storage from phone to memory card....i can send you a detailed procedure if you want
Oct 10, 2008 | Nokia N73 Cellular Phone
Tomtom ONE 3rd Edition GPS Logo
76 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
