Question about GE Profile WPRE6100G Top Load Washer
G e Profile washer
Washer will not stop filling even when water level is changed. It oveflowed but I could pump out the water
  • Anonymous Aug 13, 2008
    Water just keeps filling even when machine is off and/or unplugged...don't know if will overflow, since, luckily I caught it before it ever got to this point.
  • 943 Answers
Hi thanksfor the question i would replace the water valve this will fix ya thanks the appliance doc
Posted on Sep 27, 2008
Ge wprb8050d
when it stops filling
you fill it with a jug of water to the right level
then see what happens
if it goes past rinse
have a look at the water valve it needs to be changed
Jan 21, 2014 | Washing Machines
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Washer doesnt stop filling up with water
There is either something clogging the air tube to the water level sensor or the water level sensor itself is bad. If you need help accessing the air tube or water level sensor feel free to ask.
Dec 01, 2010 | GE Profile WPRE6100G Top Load Washer
Dishlex global 500 dishwasher says ''of '' . It will not stop making weird noises. I Have had to turn it off at the wall.
Hi there.this is (over fill error).It has over filled & flooded water down into the base.It has tripped a flood switch in the base wich turns the drain pump on even though the washer is off.You can simply try tipping the washer to get the water out or you will need to disassemble the front kick panel at the bottom front to mop out the water.The switch will reset after you do this.Or wait a couple of days and the water will evaporate enough that the pumping will have stopped & the washer should work again.The booklet for your washer has water hight level settings in it.Sometimes someone leans against the washer and presses the buttons wich changes the water level to high & thats why this has probably happened in the first place.It may need setting to a lower level.
Jun 04, 2010 | Electrolux Dishwashers
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Water will not stop filling washer
cut power to washer ..does it stop filling? suspect water level control or small hose to it is off ..keeps running in? shut off water to washer and change fill valve where hoses attach..just won't fill to top and start? raise level of drain hose up and be sure it is not too tight in drain pipe to prevent siphoning
Jul 15, 2008 | Whirlpool Washing Machines
Water is flowing into machine & it will not fill
If your machine wont fill, what IS happening? Is the pump coming on & not allowing the water to reach the correct level for the rinse cycle.
Oct 22, 2007 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
