Question about Samsung Refrigerators
Samsung refrigerator sr-l628ev ,refrigerator not working ,air mixing flow system notworking ,but freezer is working
  • Anonymous Mar 27, 2014
    I am looking for a hinge top right hand side please can anyone help
    Can anyone help me get a top right hand hinge please
I don't have a solution, but I have the same problem. Or rather I did until today when the freezer started defrosting itself too.
It sounds very similar to the RS21 problem that is on the watchdog website, but as my fridge/freezer is 8 years old I don't think they are going to give two hoots about repairing it foc.
Posted on Aug 24, 2008
I have a problem with my Samsung model no. Sr-L628EV water gathers under the chiller drawer, any idea?
Not familiar with this particular model, however it sounds like a plugged drain. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged with gunk, resulting in standing water at the bottom of the refrigerator. (A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer).
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Try c
learing the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ΒΌ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2017 | Samsung Refrigerators
Samsung fridge SR-L628EV, compressor works, all fans works but no cold air at all, it has been setting for two years but now is not giving cold air, any idea on how to fix it? Thank you
either needs freon [compressor will come on if low freon ] interior fan ,compressor internal valve damage tx valve damage condenser fan -etc can be anything with compressor running feel and look at condenser coils they should be hot and be careful of fan if not hot more than likely need freon
Sep 04, 2016 | Refrigerators
Wherecan i get a spare freezer tray
Look for an appliance parts company in your area or look on line for one. You can find a lot of places online that will have that part.
Aug 27, 2014 | Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Can i get replacement door hinge for model SR-L628EV
I have a spare fridge door with hinge for this model if interested.
Sep 22, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung SR-30NMA refrigerator compartment not cold enough. Freezer compartment OK.
ck that your fans are working and clean the condenser coils . this will help / if ice build up in back of freezer it also could have a defrost problem . blocking air flow .. ck these and if more help is needed get back with me **** ..
Jan 04, 2010 | Refrigerators
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerator is not working, however, the freezer part is?
what type of fridge is it ? had same prob with a samsung sr - l628ev fixed prob but i cant explain by email
Oct 13, 2008 | Refrigerators
Freezer compartment on Sanyo SR-3660S
Nope. That's about $800 bucks in damage that only a licensed professional CFC tech could "possibly" repair with very specialized equipment. I'm afraid that was a fatal blow to your refrigerator.
Feb 04, 2007 | Sanyo SR-3770S Compact Refrigerator
Refrigerators Logo
532 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
