Question about Microwave Ovens
Microwave GE Model JVM1540DM1WW
The mentioned microwave the fan will not turn off. I unplugged it and plugged it again but still there. it appear to be be in low but when button press wont turn off. Please help thanks.
  • 1 more comment
  • hungarianmam Sep 10, 2008
    Our microwave fan is on low, on will not turn off. When we try to turn it off, it actually operates the light, from high to low then off. When we press the light button, nothing happens. Any ideas?
  • William Miller
    William Miller May 11, 2010
    Is it the internal magnetron cooling fan or the hood / vent / exhaust fan?
    Have you recently had trouble with the stove top lights going out?
  • William Miller
    Is it the hood / vent / exhaust fan? I'm assuming it is.
    Have you recently experienced trouble with the cooktop / stovetop lights?
    There are two possibilities, depending on your answer to this clarification request.
SolutionGuy
  • 331 Answers
SOURCE: GE Microwave JE1640 works only when holding the switch
VK, most likely the switch body has become loose and it's out of adjustment. Unfortunately, to gain access to it, you'll have to remove the MW from the cabinet, set it on a suitable work area and disassemble it. Before doing anything like this, please read the following link carefully and ask yourself if you're up to it... http://www.gallawa.com/microtech/safety.html Remove the trim then remove the screws holding the MW. Pull the MW out and rotate slightly to see where it's plugged in and unplug it. Then pull it all the way out. Remove all the aluminum trim from the MW and all the screws holding the cabinet. To remove the cabinet, stand behind the MW and grasp both sides... pull back and up at the same time. Set aside. NOW!!! DISCHARGE THE CAPACITOR AS PER THE INSTRUCTIONS IN THE LINK ABOVE!!! OK, up by the control panel, you'll see the latch/lock assy. (it has 3 brown switches mounted to it). It's held in place by 2 screws, the lower screw is the one you'll be working on. Adjust this by opening and closing the door and watch the action on how it works and make your adjustments as needed. Now, you'll need to test it before reinstalling. Plug it in, BUT DON'T TOUCH ANY WIRING! Now give it a try. If you need to make another adjustment, DISCHARGE THE CAPACITOR AGAIN BEFORE DOING SO!!! Do this every time you plug and unplug! Continue adjusting 'til you get it. Now, there's a chance that one of those switches is about to go bad and the mounting bracket is fine. In this case, those switches are generic... not GE specific. Remove the wiring from the switches and make notes on their respective locations. Remove the switches from the bracket (starting from the top) and label them 1, 2 and 3. Take these to your local appliance parts store and ask for generic replacements, they are cheap... about 5 bucks each. Then replace them in the same order you removed them. And re-test. This will get you fixed, but please be careful working on Microwave ovens. They are dangerous!
Posted on Sep 27, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: GE JVM1650CH01 Microwave Template
You can download GE owner's manuals and installation instructions here.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Microwave MODel JVM1540DM1WW
I would double check the owner;s manual and installation instructions.
Posted on Nov 21, 2008
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
Microwave fan comes on when plugged in
Could be in one of the micro switches for the door or in the board. Most commonly one of the switches though.
Dec 02, 2014 | Kenmore Microwave Ovens
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Touch sreen won't work
I would suspect it either needs a hard reset (unplugging it for a few minutes, then trying again) or the membrane keypad is failing.
Instead of JMV1540BMC01, it would probably be one of these models:
JVM1540DM1BB
JVM1540DM1CC
JVM1540DM1WW
JVM1540DM2BB
JVM1540DM2CC
JVM1540DM2WW
JVM1540DN1BB
JVM1540DN1CC
JVM1540DN1WW
JVM1540DN2BB
JVM1540DN2CC
JVM1540DN2WW
JVM1540LM1CS
JVM1540LM2CS
JVM1540LN1CS
JVM1540LN2CS
JVM1540SM1SS
JVM1540SM2SS
JVM1540SN1SS
JVM1540SN2SS
Since FixYa is not currently notifying us Experts when Clarification Requests are answered, feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 08, 2009 | GE Spacemaker JVM1540 Microwave Oven
JVM1540DM1WW exhaust fan comes on at random times for no reason
I would suspect that your hood fan thermostat is intermittently shorting, or less possibly a relay on the control board is sticking.
The hood fan thermostat (hood TCO) detects excess heat from the stove top and will turn the fan on automatically at its preset temperature.
The one on your model should turn on at 133F and turn back off when the temperature falls below 104F and it should have pink wires attached. (Other models may have different colors).
A failure of either the TCO or relay can cause unwanted operation of the fan.
One way to isolate a bad TCO is to disconnect and tape off the wires on one side. Preferably the side that goes to the fan.
If you or a friend does this, be sure the wire is taped over and secure so its metal will not touch anything inside (including the chassis) and so that the wire will not be damaged.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You can unplug the oven, swing the control panel down, find and pull the pink wire on the hood TCO that goes to the fan, tape its connector over and tape the wire to another wire clear of any metal or moving parts.
There's probably no need to disconnect any other wires to get to the TCO wires..
Then reinstall the control panel, plug the oven in, and use it for a couple of days.
If the fan does not come on at unwanted times, then you know the TCO is bad and can order one.
If the fan still comes on at unwanted times, then you have a problem on the control board,
We repair these smart boards on a regular basis for customers nationwide by mail with our guaranteed $39.95 service with a full one year warranty.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Nov 07, 2008 | GE Advantium 120 Convection/Microwave Oven
How do i turn off DEMO mode on Advantium Model ZCS1001KSS?
The manual mentions a child lock, but not a demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You can download your owner's manual here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 27, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Microwave Model JES735
Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
Nov 06, 2007 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
329 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
