Question about Hannstar I-Inc TW-191D Monitor
No picture,led blinking yellow and blue
My monitor is a piece of ****. It will not power up and the led keeps blinking. I work in electronics and have soldering skills. Should I just take the power supply board and try to resolder the capacitors to make sure that there is a connection or should I try and change a couple of capacitors. I am just stuck and I can't afford to get it fix.
  • billblackbur Mar 30, 2009
    The hydro went off today and after coming back on my 19" I-INC LCD would not work. The LED in the on-off button flashes between blue and yellow and I have no picture on the LCD. The setup for the LCD does also not work. Any idea what might be wrong?
  • harleyrdr95 Apr 03, 2009
    my monitor does the exact same thing. same monitor. if the capacitors look good does that mean they are?
  • 4 Answers
Its noting to do with capaitors the EEPROM has been corrupted not sure how this happens as the write protect for the eeprom is under the control of the cpu and not hard wired.
I have repaired three of these monitors all with the same fault no components were required just the eeprom re flashed.
The EEPROMs are very cheap so I will buy a few and pre programm them for others wishing to repair there own monitors.
Posted on Jun 29, 2009
  • 1 more comment
  • chad Sep 26, 2011
    How do I contact you? Ctreatman@Gmail.com
  • David R.
    David R. Oct 31, 2011
    How do I contact you? rigdon.d@gmail.com
  • jj_x
    jj_x Aug 02, 2012
    EEPROM dont be recorded, only replaced it and ready,
Look at the Capacitors on both boards, the top of the capacitors will be puffed up,(rounded) if they are bad, change all of these, they are 470uf @25 Volts, normally six on the larger board they probably are colored green made in China of cheap quality. Also change the 330uf @16 Volts on the video out board there are four of these that normally go bad, again cheap quality parts. Also check the AC receptable when you have it apart as the solder job on the connections is of poor quality. This should fix your problem if not contact me for more info.
Posted on Nov 28, 2008
Hi Adrian
You have previously stated that you might be willing to supply programmed eeproms for I-INC CY199 monitors. I have two that are showing the flashing power light problem.
Are you still willing to provide me with a couple?
Regards
Preston
Posted on Jan 20, 2010
  • Schango Aug 04, 2013
    Adrian, Do you have eeproms to fix this problem?
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
My monitor has blanking led blue also when not is connected a graphic card and the monitor does not turn off
if i want turn off the monitor it does not turn off. Connected or not connected is the same while when it was good if there wasn't the signal output the led was orange. Now if there is or there isn't the signal output the blue led blinks
May 10, 2010 | LG Flatron L1715S 17" LCD Monitor
I-inc CY199 monitor will not turn on
It sounds like you have a monitor with a common problem, we have repaired many Hanns-G monitors with this problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 10, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor lite blinks from blue to yellow
I bought my monitor last year and had it for only a couple of months and the same thing, it is blinking the yellow and blue led. I can't believe that so many people are having the same problem. I went to the I-INC web site and there is nothing posted about this problem. I think that they really need to address this and let the consumers know what is going on with this. I feel like just trashing this monitor. I ahd to end up buying a cheap bulky monitor to replace it.
Dec 27, 2007 | Hannstar I-Inc TW-191D Monitor
Hannstar I-Inc TW-191D Monitor Logo
1,472 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
