Question about Technics RS-TR373 Single Cassette Deck
The record mode does not function on the right side.It does play on both sides!
The right hand side ie.,the record mode does not function but it does play properly. Also when a already recorded tape is placed on the left side and a blank tape placed in the right side as soon as
record button is pressed the source tape drive shuts off!
Please help!
Thank you,
Place the speed on X1 mode to make sure it is off the B mode and it should record.
Posted on Jan 09, 2009
    Sergeant:
    Champion:
  • 319 Answers
I assume you are refering to a cassette deck. Check to see if record protection tab on cassette is intact, if not you won't be able to record on that side of tape. You can use a strip of clean tape over the slot if tab is missing
Posted on Aug 03, 2008
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
Which button is which
On the top of the device are the recording indicator and built-in microphone. On the front of the device to the right of the screen: (from top to bottom) ERASE, MENU, VOLUME UP, VOLUME DOWN
The MENU button cycles through these options in this order: Folder, record condition, record quality, AVR on/off, play condition, beep tone, set year/day/12 or time, key lock on/off
On the right side of the device: (from top to bottom) RECORD, STOP, PLAY, FORWARD*, REVERSE* *(FORWARD/REVERSE can be used in the MENU mode to select options)
On the left side of the device: (from top to bottom) External microphone jack Connects headphones
Here is an online (*.PDF format) manual for the recorder: MANUAL
I hope this information helps! :-)
Mar 06, 2011 | RCA RP5020 Digital Voice Recorder
I turn it on to play for a few seconds then it stops. I think that the menu is set accordingly to play and record also.
Remove the top cover & have a look at the tape when it is in the play mode. Is the tape spilling on the right hand side? In other words there is no take up & the VCR will stop. This can be caused by either the belt or the clutch gear mechanism not turning the take up spool (it will depend on the model of VCR you have) either would best to be replaced.
Nov 23, 2009 | Sharp Televison & Video
I get the camera cover to open, but the camera doesn't record. It only works in the cassette mode ie play, stop, ff...
Check the tape carefuly. on the flat side of the cassette that faces upwards when you insert the cassette in the camera there is a 'record protect' switch which is coloured red. if it has completely covered the hole then it is in the 'save position' .in that case you wont be able to record.to record , flip the switch outwards with your finger nail. it should now expose the small hole. you are now set to record. please make sure that you set the mode select switch on the camera to 'camera' position.
Sep 25, 2009 | Sony Handycam CCD-TRV37 Camcorder
Video function
An easier way to do this is to just press the right-hand button on the round wheel surrounding the set button. This allows you to scroll through all the various record modes: Snapshot, Bestshot, Video, & Microphone.
Apr 02, 2009 | Casio Exilim EX-Z40 Digital Camera
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Technics RS-TR373 Single Cassette Deck Logo
231 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
