Question about Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 Rear Projection TV Convergence IC problem
Jimbo
I have a Zenith R49W36 TV with auto convergence. I was having some convergence issues and some ghosts on the screen. I read another post where you suggested that replacing the Convergence IC's was probably the answer. I replaced both of the convergence IC's. STK392-570 in my case and when I turned the set back on, It significantly helped the problem but did not fully solve it. I still had slight bowing of the picture and slight convergence problems. I entered into the menu to have the TV run through auto-convergence and as soon as I did that the tv shut off. I cannot get the TV to run through auto-convergence. The TV shuts off about 1 minute after turning it on. Would you have any suggestions? Any help is appreciated!
  • 34 Answers
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Posted on Dec 13, 2009
  • 12Lou2 Jan 10, 2010
    Hope this helped someone.
The auto convergence not working, the colors not lining up together
Try this with TV off Press and Hold CH- and Vol- at the same Time untill TV comes on then release ,Now you should be in factory settings,set should do AutoConvergence .
Oct 31, 2010 | Zenith R49W36 49" Rear Projection HDTV
I need to know the parameter for configuration for a zenith tv 52 inches R49W36 ,because the colors and image are really bad thanks fredy
Sounds like a convergence problem. I had the same issue. I got a repair kit from the folks at TvRepairKits.com. Worked great for me and saved a ton of money.
Dec 31, 2009 | Zenith R49W36 49" Rear Projection HDTV
My zenith projection tv model R49W36 wont aline the colors green,red and blue
Its a convergence problem. You can get complete parts and instructiosn for this fix from www.TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
Dec 22, 2009 | Zenith R49W36 49" Rear Projection HDTV
Double VIsion on Zenith R49W36
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
I have the Zenith R56W36 56 in. Rear Projection Television, and im getting a 3d affect is there a way to solve this problem?
yes the convergence needs to be repaired. You can get a kit for your model which includes both convergence ICs and all the feed resistors . the kit also includes free instructions so you can do the repair yourself. Heres the link to the proper repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/r49w36-r56w36-convergence-repair-kit/cName/convergence-repair-kits
Jan 24, 2009 | Zenith R56W36 56" Rear Projection...
Zenith R49w36 problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
Louis
May 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
My TV Zenith R49W36
my zenith tv model number r49w36 will come on with sound but no picture can someone please help
Apr 17, 2008 | Zenith R49W36 49" Rear Projection HDTV
Auto Convergence not working
I'm assuming you were having picture quality problems prior to pressing the auto convergence button. If not then there could be a problem in that circuit. More likely I believe is a problem on the convergence board assembly or in the pincushion circuits. Also, check your owners manual to see if there is a manual convergence adjustment you can do.
Jan 27, 2007 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 49" Rear Projection HDTV Logo
707 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
