Question about LG Heat cool Window Air Conditioner
I have a 15,000 btu lg thru the window unit [115 volt] and it worked great for about two months. Now, the unit cools ...somewhat badly - for about 5 minutes, and then the compressor 'clicks' "OFF" for about ten minutes, then the cycle continues and repeats.
I tried lowering the "CALL FOR" temperature ... all the way down to 60 degrees F, but that doesn't help.
The filter is clean, the unit is stable, I don't know what else to check.
Sincerely,
Richard Roepnack rroepnack@yahoo.com
SOURCE: my lg wall unit (LWHD1009R) 10,000 btu the
my window ac 1.5ton cut off with a **** at 28 deg temp with in 3 minute .room temp is 31 deg. ac is 2years old and i bring in good working condition from my brother. it was kept idle for 1 year
Posted on May 09, 2010
SOURCE: LG LWHD1800R air conditioner problem
It sounds to me like the compressor is overheating and tripping on internal or external overloads. After the unit cools down again it will try to run for a little while. Then this cycle would start over. I would check the condenser coil for dirt and filth. This portion of the unit may be on the out and backside of the unit. You should at least be able to see light through the coil.
I believe the thermistor that you removed temporarily is used for a freeze situation. I do not believe that it is your problem. Good luck:)
Posted on Jun 18, 2008
SOURCE: LG ac M483CS not cooling
It is possible that the contactor points have carbon or dust deposits causing an intermittent condition or bad connection. Why not try replacing the contactor?
Posted on Mar 04, 2009
SOURCE: LG 1200 btu ac unit works fine for 20 minutes then
You do not say if it is outdoor or indoor fan which operates. However I presume all your filters are clean and the drainpipes are clear. The only other thing you could suspect is the thermostat or air flow sensor.
Posted on Jul 02, 2009
SOURCE: I have a Lg LWC122RH-2 Window Reverse Cycle Air
think yu must take your compressor to the specialist so that they can check if cycling valve is operating. or may be wiring problem to the valve.
Posted on Oct 31, 2009
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
Nov 06, 2011 | Xantrex Technology Trace Series Inverter /...
Aug 02, 2011 | LG LMU240CE/LMAN090CNS Air Conditioner
Feb 06, 2011 | Heating & Cooling
Dec 29, 2010 | LG Heat cool Window Air Conditioner
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Jun 28, 2009 | LG Heat cool Window Air Conditioner
May 24, 2009 | LG Electronic Window Air Conditioner
May 15, 2009 | LG Heat cool Window Air Conditioner
455 people viewed this question
I am also having same problem, i am sick of this when it is bloody hot outside
