Question about Sega Master System Console
Sega master system 2
Does the sega master system 2 only work on certain tv's? i dont no which lead goes were. can u guide me through the setup process please
  • 1 more comment
  • ceejay42 Dec 05, 2008
    more infomation
  • Anonymous Jan 15, 2009
    where abouts do i put the other end of the RF cable in my tv? Ive got a lcd samsung - only have slots for PR PB and Y.??
    thanks
  • King_Pin_2K9 Apr 29, 2009
    I have a samsung le32a456c2d (module number) and i am having trouble connecting my master system 2 to the tv. I have connected the master system to the power socket, and also connected the rf cable to the tv and the tv cable to the rf switch. I have flicked through the channels i think it could be on and having no luck. Is there anything i am doing wrong?
  • 47 Answers
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Posted on Mar 31, 2010
  • 1111111m Jan 05, 2011
    i'm not sure if you're still on this site, but if so: i recently got a SMS 2 but i have no cables for it. i have plenty of ac cables of the right voltage and want to test that it works before i bother buying the RF cable. so my question is, when running does the SMS 2 make any sound?
    also, if i sorted out the power issue, is it possible to test if the video works using the video plug of an RCA cable? as this is the same shape plug.
    thanks for any help
This is how you hook it up. you put in the AC adaptor (the one that plugs into the wall) into the outlet. of course though you have to put the of the ac adaptor (small end) into the Sega. then you put the rf modulator (cable input) into the back of the tvs cable. and of course you put the end into the system. it will probablly be channel 3 you have to turn the tv too. if not, try channel 4. turn it on and see if the sega symbol appears. if you could tell me what year the tv was made in then that would help too, if the steps i gave you didn't work. hope it worked.
Posted on Sep 06, 2008
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
Have just bought a hardly used sega megasystem 2 console but it doesnt seem to work. does anyone know where all the leads etc should go? thanks
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts www.gameoz.com.au stock the a huge range.
Mar 20, 2010 | Sega Master System Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Needing instructions to set up
If I remember correctly the master system only has one lead that looks a bit like an antenna connection, one goes into the back of the console and the other goes into the antenna input on the tv.
Then you need to plug the console in to mains outlet turn it on and tune in your tv to pick it up. I normally plug it into the antenna outlet and switch my channel on to the same channel that picks up the vcr, and it works
Nov 18, 2008 | Sega Master System Console
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
I am trying to locate a auto rf switch box for my sega master system 2
Looks as if Nesfixxa400 has never seen athe back of a Mastersystem 2, there is only an rf lead port!
so you are looking for a RF splitter
you can seach for the following
master system rf switch box
Megadrive 1 rf lead with switch box
I also remeber at a 99p shop seeing a 3 way TV switching box
search for MK-3088 on ebay (below) they are compatable
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&catref=C6&from=R40&satitle=MK-3088+&sacat=-1%26catref%3DC6&a14=-24&a6=-24&a10244=-24&alist=a14%2Ca6%2Ca51%2Ca10244%2Ca3801&pfmode=1&reqtype=1&gcs=1132&pfid=1621&pf_query=MK-3088+&sargn=-1%26saslc%3D3&sadis=200&fpos=IG7+5BP&sabfmts=1&ga10244=10425&ftrt=1&ftrv=1&saprclo=&saprchi=&sass=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search
Jul 01, 2008 | Sega Master System Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Sega Master System Console Logo
2,129 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
