Question about Dishwashers
I've just moved into an old apt and would like to find a way to sanitize the dishwasher. It is an inexpensive model with the only cycles being "heavy wash", "normal wash" and "drying". Any suggestions?
  • 77 Answers
Run through short cycle with citric acid crystals(or "fruit fresh"), in soap cup. this will clean and freshen unit. if it isn't stained you may just run it through reg cycle with D/W detergent and no dishes. that should also clean well.
J
Posted on Jul 27, 2008
Hobart AM15 dishwasher is not getting to 180' on the sanitizing cycle. How can I increase the temperature? Presently, centers around 177' when it is sanitizng
Try running the hot water into the sink immediately before you turn on your dishwasher. That will get hot water from your heater to dishwasher faster & help with the sanitizing cycle heat
Sep 06, 2017 | Hobart Dishwashers
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Sanitizing has stopped working. 7 year old
It could be your heater thermostats wire or the control.if it heats during the dry cycle its probebly your control
Feb 28, 2010 | Whirlpool Dishwashers
Why sanitize button?
no, no home d/w will ever sanitize dishes, to sannitize dishes the rinse water has to be @180 degrees or above , only 1 d/w had that capability which was the old kitchenaidmod. which hobart produced for them
Oct 25, 2009 | Dishwashers
My dishwasher has the sanitize option but at the end of the cycle the sanitize light is not on. It is about 3 years old. When does the sanitize happen during the cycle so I can open the door and measure...
Check your owners manual to see when the light should come on. If it comes on due to high temps, then the heater element may be bad. Run it, then see if element is hot (be careful !)
Sep 27, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
