Question about Miele Premier-Plus Built-in Dishwasher
F84 Error code Miele
As soon as I install the dishwaser I got Error F84
  • 3 more comments
  • Anonymous Oct 02, 2008
    Our dishwasher (new) has been working perfectly well for 4 months. We then got an F84 error. We thought it may have been clogging of the rubbish trap - but emptying this made no difference. Still no solution.
  • pachuto baby Oct 18, 2008
    f84 code
    f 84 code on miele dishwasher m# g2670scvi
  • Anonymous Oct 25, 2008
    i get f84 hslf way through some programs. what can i do. send reply to daniel.garcia@imathia.es
  • lentils Dec 03, 2008
    My dishwasher commences and 1 minute into the cyle I am getting and f84 error code
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Posted on Mar 22, 2009
Hi, I have a problem when you turn on dishwasher MIELE G1730SCI after a minutefault F84 is displayed, what could this mean?
Posted on May 13, 2011
I have an F 84 error on Miele G1220 .
I have cleaned the non-return valve and there are no foreign objects that I can see restricting the impeller.
Is there anything else I can do?
There is a stainless steel metal solid tube on the opposite side from the non return valve, under the filter combination. intrying to make sure everything was free, I have inadvertantly pushed this back into the casing . I hope his has not caused a further problem.
Vernon
Posted on Jun 18, 2010
  • vkhill Jun 20, 2010
    With advice, This problem is now solved.
    F84 says water can not get away.
    The problem was seasy to fix finally, simply by unscrewing the clamp which connects the drain hose to the drain under the sink.
    The problem was at the point where the water exits into the drain under the sink. When the miele was installed, the hole was not cut cleanly into the PVC drain under the sink. Over the 4 years, the waste from the Miele had gradually clogged up the draining pipe.
    I (on advice) disconnected the pipe (from the Miele) where it enters the drain (under the sink where its goes into the U bend) and it was totally blocked. I cleaned this drain pipe, and also scraped clean the hole into the PVC pipe under the sink. there was still a problem because this drain hose from the Miele was also clogged closer to the Miele. All I did was to pull the entire Dish Washing machine out from the wall about half way (it would not come totally out because the hose was not long enough) and this was enough to clear the hose.
    IT NOW WORKS PERFECTLY and I have not had to call a repair man! Wonderful!!
    New Friend:
I bought a house that has a Miele G2243 SCU dishwasher that constantly faulted with various fault codes. The F84 was the main fault code. The recirculation pump impeller was jammed with sand, broken glass and rocks, the slide shuttle valve was also jammed solid with sand and broken glasss. The slide shuttle control rod was leaking water causing the machine to fail and the internal water proofing would cut in to keep our floor dry. There was a nest of roaches in next to the control board. There was a mouse tunnel and next in the sound proofing behind the front door cladding. I have cleaned it out and fitted a $1 "o"ring to the slide shutter control arm. The water supply was from a contaminated rain water tank so I fitted a filter. Slide shutter sync motor drives a small gearbox and unfortunatly the plastic cog was spinning on the metal shaft. I it with green Locktite 290 retaining compound. This machine is a testament to the quality and reliability that Miele build into their appliances. It's been to hell and back and survived! I am just so impressed with the design and reliability they have built into this machine. I would certainly recomened Miele Deishwashers! Previously I have owned Smeg, Seimens, Fisher Packel and Dishlex.
Posted on May 06, 2015
Miele G1023 Dishwaser ,All ligts are flashing
Must be a code. Check your manual. If it starts ticking...run
Oct 18, 2015 | Miele Dishwashers
F84 error on miele dishwascher miele g2530 sci
There is a slide valve in the machine that directs the water to the upper and lower arms. The valve can become plugged or the signal to it can become lost. The machine is not an easy one to repair and you can do more harm than good if you don't know what you are doing. To give you an idea, you have to remove the machine and turn it upside down to work on it.
Apr 18, 2015 | Miele Dishwashers
Miele Fault Code F84
Slide Shutter Positioning Fault
Miele Fault Codes
If a F84 is displayed (Slide shutter positioning fault)
The electronic board is unable to read the position of the slide shutter through the position switch. This fault is displayed when attempts to position the slide shutter have failed. See F63 (Slide shutter fault) for troubleshooting steps.
Miele G1000 Technical Information Page 219
Occasionally our Miele Dishwasher pops up with a F84 error mid-cycle and stops. I've checked filters, discharge pipes, etc.
An post in the Whirlpool archives had links which suggested the fault was to due to an internal "slide shutter valve".
http://appliancehelponline.com/miele.html
So you can read your self a link to the post; whrl.pl/RbrkDJ
I finally found a small object lodged in the ball-check-valve on the discharge of the water pump. Once removed all has been ok.
To access the check valve, remove the screen at the bottom of the unit. under the screen to the left of the water well is the cover of the pump. It has two small plastic "leaves". grasp, squeeze together, and push to the right, towards the centre of the water well. You will have removed the pump discharge and within it are rubber seals and a stainless steel ball. You can peel out the black rubber seal remove gunk and refit. Take care not to damage the seal and to replace it fully.
http://forums.whirlpool.net.au/archive/2140916
Dec 06, 2017 | Dishwashers
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
F84 error on miele dishwasher G2534SCI
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
Jan 14, 2011 | Miele Premier-Plus Built-in Dishwasher
I have a MIELE with a " F84 " falt code please help Thanks Phil
Hi
Aug 04, 2010 | Miele G848I Dishwasher
What meens the problem F84 for miele dishwaser?
Hi
Jun 10, 2010 | Miele Premier-Plus Built-in Dishwasher
Instruction manual for miele G527 dishwaser
You will find most manuals on the miele website. Go to Customer service then technical service. Then operating instructions.
Mar 10, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher stopped, F84 flashing please help. Maureen
In most cases this means the circ pump is faulty - suggest calling a Miele service rep
Sep 02, 2009 | Miele Dishwashers
Miele GS2220 Sci error message F84
Call Miele they will send a copy of the instructions booklet, I did and I got one
Nov 18, 2007 | Miele Premier-Plus Built-in Dishwasher
Miele Premier-Plus Built-in Dishwasher Logo
12,511 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
