Question about Refrigerators
Air Baffle sticks in Kenmore Elite refrgerator
The air baffle in my Kenmore 106-53203201 refrigerator sticks closed and does not allow cold air to flow from the freezer to the fridge. This causes the fridge to warm up. Typically it seems to be caused by ice and taking a hair dryer to it fixes the problem for awhile. Is there a cure to this problem? Do I need a new baffle?
  • Anonymous May 12, 2009
    my refrigerator smells like there is gas fume the water taste bitter
  • 77 Answers
Look fo an air leak. could be at ice cube chute door on freezer.
Jim
Posted on Jul 27, 2008
Kenmore 106.54584400 fridge warm, air baffle No open in normal ops. in test mode opens and closes but evap fan does not run. fan motor runs during normal ops. thermistors good in test mode.
I would meter test the evap fan it may have gone out cuz if it was ur defrost timer or cold control you would have no motor condenser fan working either? and no cold control damper working in test mode?
is the fan impeeded or just not moving?
May 21, 2015 | Kenmore Refrigerators
I'm getting water in the ice dispenser. The
First, check to see if the evaporator fan is blowing in the freezer. A common cause for this problem is an air baffle that is stuck open, or closed due to frost buildup or a component failure. The air baffle is at the top of the wall between the freezer and the refrigerator. If you check for cold air coming through this vent, you will probably find that it is constantly open. A temperature sensor (thermistor) in the refrigerator normally detects temperature and a control board sends voltage to a motor to open and close this baffle properly to control refrigerator temperature. You could have a failed thermistor, failed baffle motor or a failed control board that is causing your problem as well.
Jul 27, 2011 | Maytag MCD2257HE Side by Side Refrigerator
When you say the vent maybe blocked preventing the cold air from freezer tto reach the fridge, is the vent located in the fridge or freezer?
there are two vents, theres one to let air into the ref. sect. and one to return air to the freezer sect. Both vents should be visible from the ref section. If the return air vent is blocked then no air can come into the ref sect. also some of the inlet vents have an electronic controlled air baffle (simmular to the A/C vent on a car that you van turn on and off. If yours has one of these electronic baffles, you could need to replace the baffle or the thermostat that controls the baffle. Hope this helps.
Mar 05, 2011 | Refrigerators
How do I get to the air baffle in my Kenmore elite fridge model 106.74209401
It is visible - the trim ring is snap fit around the damper.
Remove it to see the 4 mounting screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is warm but bottom freezer works fine. It is a Kenmore with a bottom freezer and is about 10 years old
Listen to see if the fan motor is running, without the fan the air cannot circulate to the top refrigerator. If it is running then look for the baffle assy and see why its not opening. The baffle is a small door that opens and closes to keep the air going to the refrigerator from getting to cold. Basically its how the thermostat regultes the temperature in the refrigerator. Opening the baffle when it needs cold air and closing it when its cold enough. Finally check the back wall of the freezer and see if there is frost all over the back wall. If there is frost all over the back wall you are dealing with a defrost issue. Hope this helps
Jan 24, 2010 | Refrigerators
Food is freezing on our top refrigerator shelves
well i'm not exactly sure what fridge you have but that is usually caused by the what they call a baffle...which is a flap that opens and closes to let the cold air from the freezer to the fresh food side. It sounds as if the baffle is stuck open or moving way too slowly and thus freezing your fresh food. You can find a part number and price at partsselect.com all you need is your model number. Good luck!!
Oct 03, 2009 | Refrigerators
Fridge not cold - freezer fine
ice buildup will most likely block the air flow.
if so the air will not be able to enter fridge section. Check air vent in fridge side if you can hear the fan and get no air flow then its blocked - common defrost thermostat failure.
to temporarily clear the problem just use a hair dryer on the ice build up area
Aug 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge compartment is freezing
It is the part # 2315515. It is a motororized contraption that opens and closes the baffle to let the freezer air into the refrigerator. It is one part. Mine shut closed. I removed the whole thing in hopes I can do without it. It will be a trickey proposition getting the freezer temp adjusted just right enough to keep the fridge just right enough. The repair man said they are seeing alot of these right about now. They don't make em like they used to.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool side by side refrigerator not cooling
yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
Feb 05, 2009 | Kenmore Refrigerators
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerators Logo
651 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
