Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
Water on floor
Water accumolates on the floor probably during defrost cycle.
  • 77 Answers
Prbably clogged drain. remove lower bin and clean ice from drain with hot water in squirt bottle or a steamer.
Posted on Jul 27, 2008
Liquid on floor in front of refrigerator
It is probably from the defrost water collection tray under the refrigerator. Remove the bottom grill and you should see the tray. It may be cracked or overflowing if the defrost cycle is happening too often.
Oct 15, 2014 | Kenmore Refrigerators
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
We get a pool of water on the floor during the defrost cycle.
Hi.... you have a plugged drian... water can't run down the drain ... Thats why your getting water on the floor ...
Mar 27, 2011 | Amana Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
I hear water running into a tray on the floor, it went on for several minutes. Is this a function of the self-defrost?
water from defrost cycle does drain to a pan below.if water is'nt ending up on floor it is probably normal operation
Jan 22, 2010 | Refrigerators
Hotpoint ctx18 ref has water on floor on defrost cycle
Look on or under the compressor. There is a drip pan there.
Eric
Jun 29, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Drain in freezer plugs up
sometimes can be solved by loosely coiling a piece of solid copper wire around the defrost heating element and down into the drain a little. the radiant heat on the wire during defrost cycle may help keep the drain open
Mar 13, 2009 | GE Refrigerators
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
Fridge is leaking onto floor
check the "drain pan". during defrost cycle it is filled completely.Try to shift the water out of it during every defrosting cycle.
Dec 22, 2008 | Refrigerators
Leaking water from underneath
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
