Question about Compaq Presario 1830 (146107-003) PC Notebook
How to access the cmos
What keys to open the cmos settings
  • warbroglie Jul 27, 2008
    also where is the battery compartment located
    Sergeant:
  • 367 Answers
Usually del or F2
Posted on Jan 19, 2009
I have an acer aspire E1-472P-6860 laptop. Just a few days ago the keyboard stopped working. The mouse works and the the keys work but nothing else does.
Hi
access the cmos settings and try and reset the default settings
reboot press escape or F1 etc to access CMOS
25727166-kk45hi5thrg2ekkphxdk3mx1-5-0.gif select load setup defaults save & exit and it will reboot
retest keyboard
Jun 02, 2015 | Acer Computers & Internet
Where is the cmos battery located in a gateway m255-e laptop
open the top key board then under this key board you located the cmoslb_icon1.png battery and jumper settings..good luck
How to change Gateway M255 PC Notebook cmos battery Where is the mos...
May 14, 2014 | Gateway M255-E Notebook
Durabook T7M no access to BIOS
Keep trying until the keyboard is ID'ed. Unplug, remove battery, plug in, reboot. Is there a reset button?
Jan 25, 2013 | Computers & Internet
Main Bios Checksum Error!!!
Take notes of the BIOS settings of your computer for use after replacing the CMOS battery.
To access the computer's BIOS, restart your computer and press the "F 10" function key during the restarting process.
The BIOS configuration panel will then open and you can write the specific settings for your computer down to use for BIOS configuration after replacing the battery.
Turn off your computer and remove the power cable and if installed, battery.
Remove the computer hatch which will vary in method depending on the brand and model of computer you have.
On some motherboards cmos batteries are soldered in
Locate the CMOS battery on the motherboard.
The more popular model of CMOS battery used is annotated with a CR2032 label and is a round shaped button.
Firmly remove the CMOS battery from the motherboard.
Align the new CMOS battery with the positive side orientated towards you and insert into the mother board.
Restore the power cables to your computer and restart the PC.
During the restarting process, depress the "F10" function key to enter the BIOS setup screen.
Update the date in the BIOS and change the BIOS settings to match those you recorded in step one.
After the settings are updated, select the "Save and Quit" menu option and restart your computer to finish the CMOS battery replacement.
hope this helps
Sep 23, 2012 | Computers & Internet
My n6410 hard drive is password locked,but i dont know the password
In order to unlock your hard disk drive. You have to open your laptop and look for the cmos battery, cmos battery is a small circle dry cell and its number is CR2032. The cmos battery are responsible for holding the bios settings like the system date and time. The purpose of removing the battery is to clear the settings you save in your bios/cmos settings, just remove from its base and put i back after 10 seconds. With this procedure it will unlock your hard disk drive and now you access your computer. The problem here right now is the opening of your computer. You have to be careful while opening your computer you might break the casing or damage some parts. Have a nice day.
Feb 05, 2011 | Fujitsu LifeBook N6410 Notebook
How to reset cmos or bios
Hello Friend,
There are a few ways.
The easiest way is to enter the BIOS setup screen, and select the option to reset to default settings, it should be easy to find or it would be on the save changes sections.
If you can not access the BIOS setup screen, it will take physical access to the computer's motherboard. This means you will need to open up the computer case. From here there are a few options that you can do.
change the the CMOS jumper to reset.
Press the CMOS reset buttion
Or remove the CMOS battery for a few minutes.
Please note that not all manufacturer have a jumper setting or cmos reset button. Also a CMOS battery looks like a button battery.
Also if you are going to open up the case, make sure the computer is off, unplugged, and if this is a laptop the battery must be removed. Good Luck!
Dec 20, 2010 | Computers & Internet
Cmos setting wrong on start up
are you able to enter the cmos to make changes?
depending on the brand, you may hit one of several keys to access the cmos. del, f2, f10, f11, f12.
then try resteseing the cmos to defaults.
Jan 06, 2010 | Intel Computers & Internet
Unable to get into my bio settings to change from linux to windows please help
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then you can see bios setup screen.
But if you still not able to access then open cpu cabinet and pull cmos cell from motherbord for 10 minutes then refix it then all settings goes to defaults.
Then check with again F1 or F2 ,"del" ,F12,F8 or TAB or enter key.
Let me know if you need more assistance.
Thanks.
Oct 23, 2009 | Computers & Internet
Cmos battery location
open the top key board then under this key board you located the cmos battery and jumper settings..good luck
Jun 26, 2009 | Acer TravelMate 2300 Notebook
HDD password
Open the cabinet remove the batter y leave it for 10 minutes then CMOS setting will be restored to original one.
or
Use CMOS jumber to short to wipe out CMOS memory (After shifting jumber start the system check BOIS access then turn off the system place the jumber back to its position). I jumber not placed back what ever setting is made in BOIS will not stored in memory for future use since there is no continous power supply for CMOS after system turn off.
Jun 22, 2008 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Compaq Presario 1830 (146107-003) PC Notebook Logo
182 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
