Question about ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card
All in Wonder 2006 PCI Express Radeon X1300
Hy,
on the bag is written, that I have to connect my graphic card with power supply on my computer. But I do not know, where and which is the right
plug connector.
thanks in advance
  • 781 Answers
Most graphic cards pick up power from the slot they are in
if you have a lead coming from card will have small 2 pin plug on end find the connector it fits to on motherboard
Posted on Jul 27, 2008
Change graphics card
1) Follow Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static, BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again; upon your return.
(Also use Anti-Static Procedures BEFORE removing new hardware, out of their antistatic bags, or cartons. Such as a graphics card, for example )
Now we come to;
1) Are you still using the graphics the computer came with?
According to this website it is an ATI Radeon X1300 graphics card,
http://www.cnet.com.au/dell-dimension-e521_specs-339271259.htm
Example,
http://www.ebay.com/itm/HP-ATI-Radeon-X1300-256MB-DDR2-DVI-TV-Graphics-Video-Card-PCI-Express-/151012337856?pt=PCC_Video_TV_Cards&hash=item23290968c0
(The Integrated Graphics on the motherboard, is Nvidia GeForce 6150LE,
http://support.dell.com/support/systemsinfo/document.aspx?s=dfh&~file=/systems/dime521/en/sm_en/specs.htm
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6150LE )
The graphics expansion slot you have is a PCI-Express x16 slot.
It is based on the Nvidia nForce 430, and Nvidia GeForce 6150LE; motherboard chipset,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Came out on the market June of 2006.
The PCI Express 2.0 technology didn't come out, until
January 15, 2007,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
Therefore, we can assume the PCI Express technology your computer is using, is PCI Express 1.1
You can use a PCI Express 2.0 graphics card, though.
This is is because PCI Express 2.0 technology, is Backward Compatible with PCI Express 1.1 technology.
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards.
PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1.
Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0a."
(From the above Wikipedia article)
However, will you get the full capability of the PCI Express 2.0 graphics card?
NO
Will you notice?
NO
You can also use a PCI Express graphics card, based on the PCI Express 2.1 technology.
Requirements;
1) PCI-Express x16 slot.
You have that.
(The Lock lever on the end, looks as though you press down, to unlock.
Actually you LIFT UP, slightly.
Use CARE though, and do NOT lift too much. You'll see it just takes a little. It's also PLASTIC, and can break.
Lift up slightly to install a graphics card, on remove one )
2) Power Supply:
You need to look at the system requirements. Plus more specifically, the Power Requirements.
Website that sells the graphics card does Not state this?
Go to a different website that does.
Your Power Supply is rated at 305 Watts.
HOWEVER, this power supply was made back in the day, when Power Supply manufacturers were 'fudging'; the REAL actual maximum rated Wattage.
Actual maximum rated Wattage is more like 60 to 70 percent, of what is stated.
305 Watts divided by 10 = 30.5
Round it off to 30.
30 times 6 = 180 Watts
30 times 7 = 210 Watts
BIG difference.
Recommendation?
It really depends on what you wish to do, with the graphics card.
It also depends on if you are willing to get a better Power Supply.
It also depends on the Processor.
AMD Athlon 64 X2 3600+?
Dual core processor that can operate Up To, a maximum frequency rate ('Speed'), of 2.0GHz.
(Can also be stated as 2000MegaHertz.
2000MHz)
Not bad.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7620168&CatId=3585
Going to need a 400 Watt power supply, though.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2941922&CatId=3669
Same here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&Sku=T925-5002
500 Watt power supply.
Gives you more, than the recommended 10 percent extra power you should have.
This way the Power Supply will last longer, because it doesn't have to work as hard.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 24, 2013 | Dell Dimension E521 AMD Athlon 64 X2...
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Driver downloads
http://download.cnet.com/all-in-wonder-2006/3000-2108_4-94883.html
All-in-Wonder 2006 PCI Express (Powered by Radeon X1300) for quality picture, gaming, video editing and TV/PVR on your PC. Step-up to the all-in-one TV/PVR, video editing and gaming card for a complete digital multi-media system. The All-in-Wonder card delivers superior visual performance for all types of entertainment and productivity on the PC. This all-in-one card delivers 3D hardware acceleration, TV and FM radio on the PC with PVR capabilities, video editing and software, interactive program guides, stereo FM tuner and input output capabilities for multimedia devices such as DVD players, VCR's or camcorders. Enjoy the immersive visual experience ATI's All-In-Wonder 2006 PCI Express brings
hope this helps you
Jul 26, 2011 | HIS RADEON HD 4350 PCI Express Video Card
Ati radeon graphics
Um, well, I think you'll get them at ATi's website. If you have the card pre-installed in the computer when it was out of the box, then you can even find the drivers on the manufacturer's website, along with those of all your devices that came with it.
Jan 07, 2009 | ATI All-in-Wonder 2006 PCI Express ,...
Comparable cards to the ATI All In Wonder 9700 Pro 128 MB
Hello there. The Radeon 9700 Pro was a high end graphics card in its time. Today the latest Radeon cards are 3870X2, 3870 and 3850 models. The 3850, while mid-high end range, would be a substantial upgrade from the Radeon 9700 Pro.
If you are planning to upgrade your system, make sure you choose the correct type of card (AGP/PCI-E) and that your current system has a good enough power supply to power a new upgrade.
Hope this helps.
Apr 13, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
HIS Radeon X1300 Misdetected
do the BIOS update !
in the advanced BIOS features there should be a onboard GPU tab, put it on disabled or on initiate AGP/PCI first (depends on the BIOS), so to be sure that the onboard card is disabled !
Connect the display to the HIS ...video card , and at least on bootup there should be info displayed on the screen . If not than : - try to reinsert the video card (bad connection ) (also check if its a card that needs external power source ( i doubt it))
- check if the video card is compatible with the motherboard (should be in the user manual, or on the producers site ... )
- check on another comp. if the card is good ....
hope it helps u ... if not, give more details ....
Jan 21, 2008 | HIS X1300 RADEON X1300 PCIe 512MB (128 MB)...
I have a dell dimemsion 8400 pci express i want to change my video card.
ya ,
i dont think this problem is due to your graphics card,
but you have decided to change it is better.
Dec 14, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
I am trying to update my dell dimension 8400.
Re-Check your power connectors to the main board. mainly the 24-pin EATXPWR conncetor is seated right. Looking at the CPU & to its left there is a 4-pin ATA12v connector which must be connected. Bottom line recheck all internal power connectors.
Lastly there is a red slide switch on the back of PSU, make sure it is set to 115V.
Chances are something is loose. The motherboard manual for your board is a big help.
Dec 12, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
Dell computers are hard to upgrade.
hi will
yes these cards uses a lot of power. Check to see if the power supply pushes enough power to run the video card. I think these card needs its own power source so make sure you use a sepearate cable from the powersupply to the video card and not share it with other components.
if you have less than 400w powersupply thne this is morelikely your problem
good luck
smeags.
ATI All-in-Wonder 2006 PCI Express , (256MB) (256 MB) PCI Express Graphic Card Logo
88 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
