Question about Fisher Washing Machines
I have a Fisher & Paykel Excellence 7.5 kg washing machine that has developed a continuous flow with hot water tap turned on. If you turn tap off at wall and only use cold no problems. It started 2 days ago as a few drops that were noticeable with lid open.
    Master:
  • 382 Answers
Try these out ,it will surely help you..
1. Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses, and drain them into a bucket after disconnecting them).
2.Determine whether the machine is oversudsing during wash loads, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup of white vinegar in 1 quart water into the washer. Then switch to less detergent or a low-sudsing variety.
3.
The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repairperson
pleae post back on how things turned or for further help..Thank you...
Posted on Jul 27, 2008
    Master:
  • 726 Answers
Seems lik you ned to replace your inlet valve for the hot water as it needs power to open its propley buggerd or faulty its at the back of the machanine easy to replace pick up from any hard ware at a cost from $17 to 35 and its a 10 miniute job
  • 958 Answers
Hi cressida,
i think you have a leaky hot water inlet solenoid valve. these valves need power to open up and let the water in as desired but if water is leaking out in the washing machine even there is no power to the solenoid then it is defective.
a solution would be to replace the valve.
i hope i have fix ur problem
pls rate me..
tnx
drcool
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
Water drains during wash cycle
A couple things to check, is it actually turning on the drain pump? Is the water valve leaking by?
Apr 10, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Machine stops and beeps every second. Tried various points in cycle. pump appears to work then stops. Its a smart drive excellence 7.5 kg
it sounds like your out of balance switch is open circult.out of balance switch is located under control module.test for continuity on switch.make sure power is turned off first.if u have problems reply 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Hello, I live in Dubai and have a 5 year old Fisher Paykel IWM12 top load washing machine that just developed an issue. When starting a cycle it "auto senses" the water level, fills up then tells me...
First question that comes to mind is why you would want to have a machine if their is no service support where you live. I assume you have done the basics like taking hose off machine inlet and pointing it in to a tub, turn tap on and make sure there is a good supply of water. Put hose back on machine, fully open tap & start (on cold supply). Lift lid while it is filling. Check that a strong flow is coming in to machine. Then repeat with the hot tap. If water is only trickling in & sounds like it is struggling then more than likely it needs a new inlet water valve.
Jul 15, 2017 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
116 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
