Question about Nokia N95 Cellular Phone
Viberation Hi My viberation is not working, every thing els is ok,
  • Anonymous Aug 09, 2008
    My phone works well. the only problem in my phone is the viberation is not woking
  • 3 Answers
If you ******** is not working you will need to chnage the ******** motor or go to profile and check if its on or off
Posted on Aug 09, 2008
    New Friend:
  • 101 Answers
Please check in the profiles , if the vibration is ON.
This is a 12v -240v tele it just stopped working the power pack is working ok does any one no wot is wrong and can it be fixed cheers andy
First step: is it still under warantee...BRING IT BACK! If not, check for fuses and test them. Check the connections from the power pack and reseat any connections...may have loostened up from viberation.
Jan 03, 2013 | Televison & Video
Excessive viberation from 70 mph up. viberation is dominate in the handlebars and footboards
Could be crank run out..handlebar rubbers ..neck bearing grease & check tention...
May 06, 2011 | Harley Davidson FLHTC - FLHTCI Electra...
When in low idle has a bad viberation seems to to less viberation when accelerating
Common problem. Check your motor mounts and transmission mounts, more than likely it's the motor mounts. While they may "look" OK from the outside, the mounts tend to crush and not be as high as they need to be. This problem has is just a nuisance and won't hurt the performance of your TB. Typically this problem will start out only happening when it's a cold engine, then go away once the engine has warmed up. But will get worse as time goes on. Buy OEM mounts as aftermarket mounts won't be as stiff and a lot of times end up with vibration quickly after they are replaced, so don't waste our money. Hope this helps! Good luck.
Jan 02, 2011 | 2005 Chevrolet Trailblazer Ext
Ford f250 viberation high speed 65mph
Check the U-joints and center carrier bearing on the drive line.
May 24, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Viberation problem in fifa 08
wellcome,in the settings of the mode of downloading have been off not to viberate after downloading.
Jul 27, 2009 | Logitech Rumblepad 2 Vibration Feedback...
Will my air conditioner still work properly...
It will viberate pretty bad anditcould cause more trouble viberation of the tubing could lead to brittle tubes and premature breaking. replace the FBlade first.
Jul 03, 2009 | Maytag MEY12F7E Air Conditioner
Viberation.
This sounds like a case of bad gas affecting your vehicle's smooth operation. Try going to an auto parts store and getting some gas treatment next time you need to fill up. Add it to your gas tank at that time, and it should help. I had the same problem, and this worked for me. Good luck!
Nov 11, 2008 | 2008 Toyota Camry
Nokia 6300 will not switch off
it requires software formatting..try bringing it to a specialist
Jul 06, 2008 | Nokia 6300 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
