Question about Mitsubishi WS-65513 65" Rear Projection HDTV
My misubishi diognostic
Hi big irish i just got back from vacation turned on my tv it was good for about 2 days then this morning it turned of i did the self diognostic test and it reads no error (1blink space 2 blinks ) so what can be the problem....
thanks
fidel509
Im sorry i just got this email but i dont know were there located or were there at are you refering to the projector lens plug .so what do u mean unplug and turn it back on. while unpluged if so what am i looking for....
sorry im new to this.
Posted on Aug 01, 2008
  • Mitsubishi Master
  • 8,617 Answers
Unplug the convergence yoke plugs all three and try powering up the set. then let me know if it powerd up. Please reply to this same post when responding.
I cannot get the wlcome screen on my TV
Good Day;
Try resetting the TV by unplugging the power cord for 2 to 5 minutes then plug TV back in.
Good Luck, big IRISH.
Sep 26, 2008 | Televison & Video
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Sep 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
60" Mitsubishi TV - Approximately 6 years old
Good Day;
Try resetting the TV and any BOX by unplugging both for @ to 5 minutes then plug back in.
Aug 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Screen is blue
Good Day, o_fraile;
Blue screen normally means your TV is not receiving a signal.
1. Reset TV by unplugging TV's A/C cord from source for 3 to 5 minutes...... plug back in
2. Do the same to "BOX" ( cable, sat & etc)
3. Make sure input is the correct, all inputs, turn DVD and others on and go through inputs.
Aug 21, 2008 | Televison & Video
Mitsubishi TV
Good Day, Ritz1234;
Okay, you made sure lamp was seated properly. GOOD!!Now the hard part but the "fix'. On the TV's power supply you will need to change some cap's. But to verify this remove the panel in front, just to right of the lamp panel. Now look closely... reset unit, look, and turn power on, into second panel's opening... if you see the lamp come on for 5 to 10 seconds. Then lamp goes out, then power supply caps need to be replaced.
The power board is on the left hand side of the TV (from the back), power board is in the very back of that left hand ***'y. To repair the supply you will need 4- 1,000ufd 35v, 2- 3300 ufd 35v and 2- 2200ufd 35v caps on that board. They are the only ones on the board, with replacement in hand it will easy to identify parts to replace.
Good luck, if any concerns let me know, good luck, big IRISH.
Jul 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My misubishi
Good day, fidel509; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Good luck, I hope this will get you started in the right direction, big IRISH.
Jul 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
TV Troubleshooting
Good Day Joseamunoz2;
It sounds like the convergence circuit has failed, but it does not normally cause the TV not to turn on. Until you get a signal (cable) back on, double check your concerns.
Jul 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Tv will not turn on
Good Day;
I hope you have solved this concern by now, if not call an Authorized Service Center and have them come out and give you a written estimate. Good Luck, big IRISH.
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
