My washer leaks during spin cycle - Washing Machines
You have a failed tub seal and bearing. common problem with these. i replaced mine completely. big job.
Posted on Aug 20, 2008
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks during spin cycle
hi sir, if water leaks during the spin cycle please check the following:
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
mostly water leaks due to the above problems. kindly check them.
kindly rate me.. thank you for using Fixya.
Feb 11, 2010 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
