Question about Whirlpool Duet GHW9150P Front Load Washer
I got the F dl
I got the dl andtried to unplug it for 10 plus minutes. Then i stuck my finger on the white door lock piece and it clamped down. Now it is locked and i cand get it up to shut the door. I got the Fdl when i tried running a load, and the door wouldn't lock to start the cycle.
  • brcox55 Aug 28, 2008
    white plastic piece that holds the door closed is in the lock position and when it was up ie unlocked the DL would flash and not lock' how do i get the door to unlock and then how do i get it to lock with the door closed and work
  • 63 Answers
Main ccu board bad
Posted on Jan 20, 2009
Not really a "solution" but after multiple issues with the "DL" coming on, i've managed, at least in my mind, to associate that although the washer is touted as being able to handle large loads, everytime i wash something larger than average, i will get the DL code. The solution has been a repairman until i go thru a routine of unplugging, close the door, it will flash the code, i will press stop and then start multiple times. after awhile, this can be a day or whenver i pass by the washroom, it will either feel sorry for me or disgusted...but it will start. tonight i am again washing...ah, hard earned victory but at least i have clean clothes!
Posted on Aug 27, 2008
  • 725 Answers
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
most likely you will have to replace both door lock and ccu
Posted on Jul 28, 2008
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
When pressing the start button a "DL" indicator flashes and then a "F" indicator remains, door does not lock and the washer will not start.
that is the code for door lock. ensure its not stuck or something in rubber boot stopping door from closing all the way and try to reset it.
maybe by unplugging it for a coupkle of minutes
May 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can't get door opened. model #GHW9150P
the f represents failure and the failure is dl door lock .if i was there as a repairman i would inspect the wiring from the door lock assemblie to the [ccu]computer console [the button area you push to start]also inspect door lock assemblie and the computer.if looks normal i would replace the cheapest part first[but not the wiring if inspection ok]so thats the door lock assemblie.you can unlock door by removing bottom front panel and feeling up in the door lock area ,their is a tab to pull down,then door will open.to replace door lock assemblie you go thru tub boot area by door latch. hope that helps God bless ,tom
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
191 people viewed this question
Dan Webster
Dan Webster
Sal De
