Question about IOGear GCS632U 2-port KVM Switch
Did you figure out your KVM?
I have the EXACT same problem you had. As soon as i hooked up my external hard drive (to a USB on a completely different USB port, no less...) the keyboard port stopped working. The keyboard works in the mouse port, but nothing will work in the keyboard port.
Did you ever figure this out?
  • Aubreynna May 11, 2010
    Have you tried connecting the mouse to the keyboard port? If yes, is it working? You mentioned about your hard drive, if you connect your USB hard drive is that the only time the keyboard port won't work? or the keyboard port doesn't work with/without the connected external hard drive?
    Problem Solver:
  • 6 Answers
If you tried to connect your mouse to the keyboard port and still it doesn't work. Power cycle meaning unplug the KVM from the CPU, monitor, keyboard and mouse. Then wait for about 30seconds before reconnecting again. If you still encounter the same problem that the keyboard port won't work then it means that keyboard port is defective. Replace it.
Posted on May 19, 2009
I know there is data on my phr-250a mcally external hard drive but it's showing empty folder
Leave it connected to your computer and try a restart.
If the folder is still showing as empty, power down the computer then disconnect the external drive.
Power on the computer and connect the external hard drive to a different usb port.
I had this exact problem with a 1000 Gb external drive that was full of movies and music. I thought it had all been lost .. After 2-3 days and repeated attempts of restarts and power-downs/different usb ports it suddenly was recognised again and has worked perfectly since
Jun 07, 2013 | Macally Phr-250a - Usb 2.0 2.5-inch Ide...
Blinking not mounting?
if you are a front usb port on your desktop , switch to rear one. or try it on different pc, if aproblem continue that means that the usb controller on your external HDD is malfunctioning , you should have it fixed or replaced with exact same one
Feb 08, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
When hooking up my 120 Gb external hard drive to my laptop, I noticed there was an additional power supply required, DC by the look of it. I can't seem to find the correct size of outlet, or even an...
hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
Jul 16, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I have a Samsung G2 500GB hard drive, and every time I plug it into a computer, it will say that the USB Device has malfunctioned and is not recognised. I have tried plugging it into different computers...
Sounds like a driver issue with your hard drive. If you have the software that came with the hard drive you may be able to reinstall the drivers. Or, alternatively, look up the hard drive online and download the drivers from Samsung's website.
Mar 11, 2011 | Samsung G2 Portable External HX-MU050DC/...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
Can external hard drives be "piggy backed"? I have
Each external device connects to one USB port on your computer.
So, you'll have no problems running two devices at the same time, in different USB ports.
Dec 13, 2010 | Seagate FreeAgent Pro 1TB External USB...
I have a maxtor mini one touch 160gb external gard drive. i have tried to plug it in with this usb cord (i got a new one because i lost the original one) it is making a beeping noise and the power light...
ou have a usb controller board that is malfunctioning and it or the case for the usb hard drive needs to be replaced.
the power regulator that is built into the usb controller is not working therefore the usb logic circuit cannot transmit the signal to the PC viia the USB port and will not recognize the device. You can order or purchase a new case that will accommodate the hard drive from your local computer store.
Aug 19, 2010 | Maxtor OneTouch III Mini Edition 120GB...
External hard drive not recognised is practically full but being asked to format i don't want to lose everything on there
did you hooked up using USB port? try to use a different hard drive usb port. make sure the hard drive casing is seated propperly.
Feb 24, 2010 | Computers & Internet
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
454 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
